heated leathers
Guest speedy
Guest speedy
only had the car a week now so unsure if they are original the only thing i have to go on is i have every recipt for anything the car has ever had on down to new wheel bolts where would i find the module bit of a novice at car diy
cheers
Look under the seats and check that there is a bunch of wires (with a single multiplug) connected to each of the seats.
There should also be a relay underneath each seat.
If all is present and correct, park the car somewhere quiet and slowly turn up the heated seat dial and listen for a click from the under-seat relay. Repeat for the other seat.
