Will this battery be o.k?
Hi.
So after installing a Turbo and having the battery relocated to the boot I am loosing my dash guages when the car is running which I think is a earth issue from relocation.
As im now fed up im going to put everything back up front but need to use a battery as small as possible to fit upfront with all the Turbo pipes etc but powerfull enough.
Racing battery as sold by DeamonTweaks...
Did you use a thick enough wire and a good junction box up front mate as I've relocated batterys in 2 of my cars and never had any problems. I just went to the scrapyard and found a bmw and took the whole battery wire and junction box out and it works spot on. The wire is really thick about 13mm so there is no power loss
Well i had it done...but not sure on the junction box if honest,dont look that great. Ill take a pic later of it.
I bought BMW cable anyway and that is being used. Only the pos though.
So I just checked where the earth frol battery was located and he ran it to the body just infront of the back seats...so I took it off and mounted it to where it is now in the pic to see if that will make a difference but it doesnt... Will the lenght of the negative cable affect it as it is a bit long...
At the back...
Block at front...
