Hutch 14 Posted December 7, 2013 Report Share Posted December 7, 2013 Hi, I need to present a jack or pair of RCA sockets somewhere on the dash or possibly in the Glovebox. In terms of ease of wire routing from rear of headunit, which locations might be best? Also, I'd love to see any pics of your auxiliary inputs and leads for ideas. Cheers! Ben Link to post Share on other sites
CALICO 130 Posted December 7, 2013 Report Share Posted December 7, 2013 Why do you need a pair of rca sockets Usb is the way forward either in the glovebox or into centre console under heaters Link to post Share on other sites
Hutch 14 Posted December 7, 2013 Author Report Share Posted December 7, 2013 I'm adding a Bluetooth receiver that'll be ignition powered, but want a secondary input for various other devices. How much dash has to be removed to get to wiring to the glovebox? Link to post Share on other sites
palmer 17 Posted December 7, 2013 Report Share Posted December 7, 2013 If the wires coming from headunit an u dont have freakishly big hands u should be able to run the cable without taking dash apart, just use the space where headunit would sit Sent from my GT-I9505 using Tapatalk Link to post Share on other sites
Lukey. 381 Posted December 7, 2013 Report Share Posted December 7, 2013 top or bottom glovebox? I have USB and iPod coming through an existing hole in the top glove box next to the light Link to post Share on other sites
Hutch 14 Posted December 7, 2013 Author Report Share Posted December 7, 2013 It's on a MK3 Highline, only one glovebox low down under airbag. Ok I'll see if my hand will fit through headunit slot, it all looks very closed off back there! Thanks Link to post Share on other sites
Lukey. 381 Posted December 7, 2013 Report Share Posted December 7, 2013 If you take the airbag out (carefully!) you will have total access Link to post Share on other sites
