What's easiest way to free up kW coil overs?
  • 3 weeks later...
Wire brush to clean up around under the adjuster as much as you can. Prefer gt85 over wd40 or some lock shock stuff there is a wd40 version or Halfords own brand.
Vice the shock up and use a big heavy hammer and keep whacking the adjuster.
If no budge you can heat up the adjusters and that will definitely get them moving. Just be careful not too heat too much as you don't want to damage the shock internals.
I kept touching the shock body whilst heating as soon as felt it was getting a bit too warm I stopped and commenced hammering.
