96 vr6 1st ever project build thread,
  • Replies 523
Popular Posts
It's alive! https://vimeo.com/127356810 Another box ticked on my bucket list.......own a supercharged car! Love that noise!
Got a few more bits done this week, not as much as I would have liked as works been busy and I've been waiting on bits including the longer belt for the charger that's coming from America and is silly
Finally had some time recently to get a start on fitting the air ride onto the car, I managed to get a hardly used Airlift V2 digital set up with twin compressors at reasonable price, Started with s
Posted Images
Having done this myself I do always like to see others delving into full sill, floor and arch butchery :D
Didn't think it'd be this bad! I thought, bit of surface rust,clean it up treat it underseal it or whatever.........wrong!! But I suppose if you're going to do something you got to do it properly! Nearly there with the rust now so I can start on the rest of the bodywork, which is good because I hate doing rust!
A couple of pics of one of the wheels bolted on,got a pair of 35mm spacers to try them out,deciding on and finding tyres that fit is proving a pain in the arse, as the 2 sizes I want don't seem to be made but the same company and I don't really want odd makes front to back!
Edited by bennyk
Made some progress over Christmas which started with sorting some tyres, decided to go for some continental 195/40r16's and got a pair of 35mm fk wheel adaptor/spacers. Wasn't sure if they would be a bit to big,but they seem to make the wintercults sit perfectly,so I'll get another pair, here's how they look;ydyne7a7.jpgjyjypegu.jpgzumusetu.jpgta6anyha.jpgama9uvub.jpg
Also got some repairs done on the rear, though I kept forgetting to take photos! Hopefully it'll all make sense, when I bought the car it had a bit of damage on the near side rear quarter below the light,probably had been reversed into a post or something,you might be able to see some of the damage above, I managed to get it straightened with a bit of wood and a big hammer! Then cleaned up any signs of rust and put a few extra tacks down the joint between the panel as it had been opened up by the knock. 6etahyhy.jpg
Also did the bit of damage on the arch whilst I was here. atagymun.jpgy7y7eta3.jpgvebave8y.jpgy6uzyga5.jpgu8yzu2aj.jpg
Edited by bennyk
Whilst repairing the quarter I rolled the rear arches,not sure if I needed to with the 195 tyres but thought it best as it's all getting painted and it should allow me to go lower;) started by cleaning back all of the thick factory sealer, zinc primed it and left it overnight, then put a smear of terason 6 in 1 body sealer around the inside. vemu2yza.jpg
Then I used a hammer and dolly and got it as flat as it'll go, so it looked a bit like a mk4 golf rear arch, then I 2k primered it along with the damage on the quarter and smeared some more of the sealer around it to seal it and hopefully hold any rust back for a good few years! By the way I did have the lights and bumper off but I always constantly try stuff on to check gaps etc! ty7adu8e.jpgune3yde5.jpgene4y3uz.jpg
Got this bit of rust sorted too,the car at some stage in its life has had an offside rear quarter and I don't think it'd been done very well to say the least! So I cleaned out all of the sealer which had been put straight onto the metal without any primer causing it to rust,though it was just a bit of surface rust so I cleaned it up and treated it with jenolite then put a nice thick coat of 2k primer on it. So it looked like this in the end; ynytu6ud.jpgequhuvev.jpgrytepege.jpg
Got a couple more bits done at the weekend including getting the paint stripped off of the bonnet, as it had been painted before and for some reason started to blister all over like this;yqupuhud.jpg
There were loads of bonnets in red on eBay for £15, that could've had a quick rub down and paint but they were all at the top of Scotland or down in Cornwall!! So the old one was original and looked like it'd only been painted for stone chips so I stuck with it. Started by slopping on some paint stripper and covering it for a couple of hours;6egyzy6e.jpgrype6y7y.jpg
It did most of the work and the bonnet turned out to be very straight with 2 tiny little dinks on the front edge, so I finished it off with a D.A with some 120 grit then 240 and put a coat of primer on it along with the U.S spec bumper which was stone chipped to f#%k! And happened to be red under the terrible coat of blue that had been put on it, next up is to shorten the rear number plate recess. equbepuh.jpgmujuguzu.jpgana9y7ep.jpg5u6utuhe.jpg
Edited by bennyk
Hello mate,thanks for the compliments! The wheels are porsche wintercults apparently there was an option to have these as a set of winter wheels for your porsche 928... I think, if anyone knows better I'd love to know more! Didn't realise quite how rare they were until I got these.
I've spent the last weeks worth of tea breaks and lunch breaks doing the number plate recess so here goes;
I wanted this to have a real factory look,so it will probably only be us geeks and anoraks that'll ever notice it! And just to see if it was possible, I have still got the old tailgate if it all went tits up anyway!
Started by measuring up and cutting some big holes; ynezume9.jpgyha4y7up.jpg
Then I measured up with grab handle and trimmed a section out whilst constantly checking, measuring and trimming;urajy2an.jpgu5atapyz.jpg
Once I was happy with the fit I got it cleaned up and tacked in place;qeme8e2e.jpgyna3yqe9.jpgby4u7upy.jpg
Then got some sections trimmed up to fit the holes and got them tacked in then got the whole lot welded trying my best not to put to much heat through the panel;du6uvevy.jpghu9e7udy.jpgygavehy6.jpg
Got the welds ground down in case you hadn't noticed I've also got rid of the wiper but wanted to keep the badge;pa6aqy9y.jpg3u3aqe5e.jpgyrynujuh.jpg
Had to a bit of heat shrinking as there were a couple of wobbles here and there,then feathered out all the rough edges and gave it a skim of finishing glaze;ydypa2yj.jpgdadu2u2e.jpgana2u4yz.jpgusu6u5u3.jpg8aqehe6u.jpg4ymahyze.jpg
Then was priming something else so got it masked up and got some primer on it;udedy4e7.jpg
Here's a couple of when I got it on all 4 wheels for the first time in a while this week;y4emy8ev.jpgupa3u9ez.jpg
Yeah agree with that,all of the badges will be going back on,got no problem with people knowing what it is! Keep forgetting to get a couple of pics of the finished recess with the handle on.
Got quite a bit done in the last few days, the rest of the car is now in primer as I used a day of holiday to try and push it along and took a couple of wheels home at the weekend and got most of the prep done on them,so managed to get 2 painted as the other 2 were still on the car. But at least I could get a before and after; mudezuby.jpgahy3y2e2.jpgme5agyqy.jpg
I also rubbed down prepped primed and painted the inside of the wheels as the were a bit scabby not at all bad for twenty something year old wheels though, didn't think they bad enough to warrant acid dipping or shot blasting plus that would cost and I'm to tight! So first I used a nylon strip and clean wheel and got rid of most of the corrosion; ty5e8ase.jpgpaqa8use.jpg
Sorry had to switch to my phone because the iPad hadn't picked all of the photos up,I hate technology and computers! Did the repairs on the face just a couple of bits of corrosion and curbing then red scotched the whole thing in with a bit of wheel cleaner added; by4e6yjy.jpg
Then once all prepped up get them in the oven and 2k primer them in and out;yve5e6u2.jpg
Then as I'm using solvent base coat (we usually use water based) I could cheat a bit and go straight on top of the primer with the colour only on the inside though; 6epepa8a.jpgdedu8eza.jpg
This makes it easier to make a nicer job of the face when it comes to painting them.
I'd got rid of most of the little car park dings and one or two rust scabs on the doors and quarters over the last couple of weeks so it was a quick d.a down with some 240 grit and red scotch brite;3u2eruqu.jpge9uresaj.jpg
A quick couple of the difference of wheels from behind as I'm still waiting for another pair of adaptors! 5usy9aze.jpgy2y7etap.jpg
Then primer, one coat on the bits of damage then another two on the rest of it and a coat on the new wings more so it's all of the same colour so I don't get any nasty surprises with colour when I paint it! navety5y.jpgu6ezanum.jpgde6e6u4e.jpg
Also got some colour on the wing shuts so I can sealer the wings on as per factory and had a spare half hour left on my 'day off' lol so made the most of it and prepped and painted the grill/ headlamp panel to keep the motivation going!
Edited by bennyk
Yeah the hardest days work I've done for a long time! Don't tell my boss that though lol! Yeah wheels are staying silver,ford moondust to be exact as it's a nice fine bright silver, I've pretty much done black and gunmetal wheels and all the boys with there corsas and lupos have done all the other colours! They look like this now; ymegu5es.jpgbyseme5y.jpg
The centre caps were a bit of a state when I got the wheels and I was going to buy a new set,but at over £150 for a set of metal ones with emblems I thought I'd have a go at restoring them, they looked like this when I got them;u6e9u2a8.jpg
So I got my dremel out with tiny wire wheel to get rid of the corrosion and flakey paint( my girlfriend loved me doing this in the living room whilst she was watching something on the tv;)!) here's a before and after;arybyjej.jpg
Then primered them a couple of times because they were a bit pitted, then put a coat of silver base on them;yqu4u8ud.jpg
Visited hobbycraft for some model paint and fine brushes! This must be the slowest drying paint in the f-ing world! 9ytypy7y.jpg I forgot to take photos at this point, I painted the whole emblem gold the did the red and black details after,left them on top of the radiator for a day then put 2 coats of clear coat on them at work; here they are in the wheels,I'll get a close up tomorrow,they're not perfect but I don't think many people will notice; y5upegem.jpg
Also got the wings bolted on and the engine sitting on the hockey pucks,just having trouble finding a longer bolt for the front mount though. tabubude.jpgyrarasut.jpg
Next stage is windows out and start prepping for paint!
