Central locking/alarm module
Chaps, I have a Mk1 VW Sharan VR6  R reg.
My central locking & alarm failed yesterday.
I thought classic water in the seatwell and a soggy control unit but nope - bone dry.
These are the symptoms :
No central locking via the key (never had fob remote) Drivers door, passenger door & rear tailgate will only open mechanically with the key.
The rear 2 passenger doors are permanantley locked - wont open from inside or outside.
The petrol flap is open (the pin is at the rear all the time).
No courtesy light system working   ie usually remove key & all comes on or even opening a door - nothing comes on. The mechanical switches on the lights work ok.
The control box under the seat clicks rapidly (like a stuck relay) but intermittantley - remove the fuse & obviously stops but also isolates all the courtesy lights etc.
Removed the control box today - all looks good, no obvious signs of damange or water ingress etc.
So - do these control units (7MO962257J) just blow ?
The only other clue is the usual problems of the tailgate wiring chaffing and breaking but all have been repaired, one did work loose again so maybe shorted out - earthed ?  would that blow the control unit ?
If I have to buy a new one que sera - but any tests first to see if I have missed anything ?
Thanks for your help :-)
