A little help needed people, I have got a 1995 VR6 where the engine has died and I have managed to find an R32 engine, how easy is this to fit and do any of the ancillaries fit across? will it need an R32 ecu and will that fit the VR6 fuse board with a plug and play?
Any advise needed
many thanks
Take a look though my build thread on here mate, there's also another build thread on here by Absy,
Theres quite a few different ways of doing things but physically it drops straight in on the mk3 mounts (worth upgrading)
Stick with oem management so yes the ecu from the donor vehicle or a late v6 4motion would also work but would then need ecu work and de immobilising etc.
Custom loom would need to be made and spliced into old vr6 loom to use the original fuse box.
Have a look through the threads on here and if you need any further info then ask away.
