Sign in to follow this
Pieman
Fuel pump wiring
Help Please.
I am getting no power to my fuel pump.
I have checked the relay, had 2 from other cars that are known to be ok, and its fine, so too is the fuse. The engine start's and run's ok with easy start. Tested the fuel pump with a live and it pumps. I am get a live for the fuel gauge and that works fine.
Any idea's???
It could be damaged fuel pump wiring or bad connection on fuse box, check all connections and fuses.
On fuel pump connector you have: red yellow (+12v for fuel pump)
purple black (signal for fuel level)
blue brown (signal ground)
brown (fuel pump ground)
