mk2ben 0 Posted October 2, 2012 Report Share Posted October 2, 2012 Hi i recently bought a supercharged vr on the cheap and am having problems with it, Is a Z Engeneering on with previous rr of 286hp at storm. Its really not performing as it should ive checked and its running approx 10psi of boost. However is very down on power still Its flat right the way through th rev range and if i am honest doesnt feel that much faster than my standard car, It also has a load screatching noise from 4k onwards as if the belts a slipping, However this is not th case as its got toothed belts. Im really lost on this one hope some one may be able to give me some advice. Thanks Ben Link to post Share on other sites
UnitedMotorsport 55 Posted October 2, 2012 Report Share Posted October 2, 2012 What injectors are fitted? Stock ones are a brown colour. Link to post Share on other sites
mk2ben 0 Posted October 3, 2012 Author Report Share Posted October 3, 2012 Its got red top injectors fitted Link to post Share on other sites
russj249 2 Posted October 3, 2012 Report Share Posted October 3, 2012 Just for the loud screaching noise, and metal filings or anything in the boost pipe? Has a turbo at work recently that the bearings went and impeller was shifting into the casings under load, making a hell of a screeching noise, and as a supercharger is kind of a belt driven turbo it could be a bearing issue somewhere. Link to post Share on other sites
russj249 2 Posted October 3, 2012 Report Share Posted October 3, 2012 *any metal filings... And do the injectors say 0280 150 321? The Saab turbo injectors. Link to post Share on other sites
mk2ben 0 Posted October 4, 2012 Author Report Share Posted October 4, 2012 I will check the injector code and no defo not and problem with impeller it here's no play in the shaft Link to post Share on other sites
FishWick 21 Posted October 4, 2012 Report Share Posted October 4, 2012 boost leak? Link to post Share on other sites
mk2ben 0 Posted October 4, 2012 Author Report Share Posted October 4, 2012 I've already hecked Link to post Share on other sites
UnitedMotorsport 55 Posted October 4, 2012 Report Share Posted October 4, 2012 Check to see if there has been any resistors added to any of the wires on the MAF loom. Link to post Share on other sites
mk2ben 0 Posted October 5, 2012 Author Report Share Posted October 5, 2012 Will check tomorrow off the top of my head I don't remember seeing one Link to post Share on other sites
rodney 17 Posted October 5, 2012 Report Share Posted October 5, 2012 is your clutch good as well? Link to post Share on other sites
mk2ben 0 Posted October 6, 2012 Author Report Share Posted October 6, 2012 Yeah clutch is all good I've just realised there is no re circ valve fitted could this be causing problems .? Link to post Share on other sites
Gazbarber1982 3 Posted October 16, 2012 Report Share Posted October 16, 2012 The belt that runs the power steering and alternator could well be slipping which would cause your screeching. It could also be any of the bearings. If it's the charger bearings, they can be replaced for about £250 but you can't get the oil seals and I know because I've tried!! After buying and replacing the bearings, I sent my charger off to have it modified for new seals. In the end I part ex'd mine for a brand new one from Robert @ Ruf kompressoren. Link to post Share on other sites
mk2ben 0 Posted October 16, 2012 Author Report Share Posted October 16, 2012 Thanks for your reply gaz I suspect it is the aux belt as the alternator is slightly polished and on the odd occassion when giving thee hammer the head unit turns off making me think this is perhaps something to do with the belt slipping. It had a rebuild not long ago so im hoping its not that. A local tuning place claims to know the original person who made the z engeneering charger and claims to be able to get seals. Im going to put the kit on my other car as im breaking the one its fitted to now so i will have to wait and see Link to post Share on other sites
