Dirtysanchez 0 Posted June 2, 2012 Report Share Posted June 2, 2012 So, today I acquired VAGCOM and did a scan. I'm pleased to discover the car was nice and healthy apart from the following:Address 03 ------------------------------------------------------- Controller: 3A0 907 379 E Component: ABS/EDS ITTAE 20 GI V00 Coding: 03704 Shop #: WSC 000009 Faults Found:00283 - Front Left ABS Wheel Speed Sensor (G47) 35-00 - -00285 - ABS Wheel Speed Sensor: Front Right (G45) 35-00 - -01276 - ABS Hydraulic Pump (V64) 16-00 - Signal Outside Specifications00290 - ABS Wheel Speed Sensor: Rear Left (G46) 35-00 - -00285 - ABS Wheel Speed Sensor: Front Right (G45) 04-10 - Mechanical Malfunction - Intermittent00290 - ABS Wheel Speed Sensor: Rear Left (G46) 16-10 - Signal Outside Specifications - Intermittent00287 - ABS Wheel Speed Sensor: Rear Right (G44) 35-10 - - - Intermittent00287 - ABS Wheel Speed Sensor: Rear Right (G44) 16-10 - Signal Outside Specifications - Intermittent00668 - Supply Voltage Terminal 30 16-10 - Signal Outside Specifications - IntermittentNow, this doesn't come as a great surprise to me, as one of the previous owners has removed the ABS light altogether, so I thought something might be up. Aside from testing/cleaning/replacing the speed sensors, what else do I need to do?Also, where are the speed sensors located? On my e46 they were located in the hubs and were an arse to get out without snapping!I'm not happy to just leave the ABS bulb out, I'd rather identify the problem and fix it properly! Link to post Share on other sites
craggsy 91 Posted June 2, 2012 Report Share Posted June 2, 2012 First off clear the faults and see what comes back. As some of them might be stored from previous owner.ABS sensors are in the hubs but fairly easy to get to Link to post Share on other sites
ashmk3 0 Posted June 2, 2012 Report Share Posted June 2, 2012 Fronts are in with one bolt, then the backs the same but unplugs from under the rear seats. Really simple to get too. And Craggsy that module seems to be fine it said rear right so I swapped plugs over and it moved to rear left. New ones ordered. Link to post Share on other sites
Dirtysanchez 0 Posted June 2, 2012 Author Report Share Posted June 2, 2012 Excellent, thanks guys, I'll give this a go tomorrow! Link to post Share on other sites
craggsy 91 Posted June 2, 2012 Report Share Posted June 2, 2012 Fronts are in with one bolt' date=' then the backs the same but unplugs from under the rear seats. Really simple to get too. And Craggsy that module seems to be fine it said rear right so I swapped plugs over and it moved to rear left. New ones ordered. [/quote']Cool glad ya got it sorted Link to post Share on other sites
Dirtysanchez 0 Posted June 4, 2012 Author Report Share Posted June 4, 2012 Well, I cleared the faults down, which only left three (there are only two shown below, I forgot to copy the codes before I fixed and cleared them again):Control Module Part Number: 3A0 907 379 E Component and/or Version: ABS/EDS ITTAE 20 GI V00 Software Coding: 03704 Work Shop Code: WSC 000002 Faults Found:00285 - ABS Wheel Speed Sensor: Front Right (G45) 35-00 - -01276 - ABS Hydraulic Pump (V64) 16-00 - Signal Outside SpecificationsSo, I took the front wheels off to have a look at the sensors. I wasn't surprised to find that Stevie Wonder had also had a go at the wiring on these (no jokes, the wiring on this car has to be seen to be believed). The front left sensor had both wires cut in half, then fixed with crimp tube connectors. Except, Stevie had forgotten to crimp one end of the connectors so the wires just fell out and did nothing. Not only that but the wires were looking pretty worn anyway, so I cut the whole lot out and soldered new wire in with some heatshrink tubing to insulate it.The front right was a similar story, except that these wires had just been worn away (possibly from rubbing on the wheel as they weren't located in the little holders properly). Again, I cut them out and re-wired them properly.After this I went for a drive and performed a couple of brake checks at around 40 mph (I made sure there was nobody behind me ). I found it was actually REALLY hard to make the wheels lock up, but they did. Got home, plugged vag com in and got the two error codes at the top of the page, which some googling has suggested could be a faulty ABS ECU and sensor.TBH the repairs I've done today are only temporary, so I'll probably end up replacing all the sensors and the ECU anyway. This car has so many little niggles but I LOVE it lol. Link to post Share on other sites
Lukey. 381 Posted June 5, 2012 Report Share Posted June 5, 2012 Have you tried unplugging the massive multiplug on the ABS pump? I've had the signal outside specification before and leaving the module unplugged for 20 mins fixed it Link to post Share on other sites
VR6Pete 1,456 Posted June 5, 2012 Report Share Posted June 5, 2012 Remove all the plugs, give them a clean and spray some wd40 Link to post Share on other sites
Dirtysanchez 0 Posted June 5, 2012 Author Report Share Posted June 5, 2012 Handy tips guys, thanks very much, I'll go pull the multi-plug out now. The sensor plugs will have to wait until it's not pouring with rain lol. Link to post Share on other sites
