michael5556 247 Posted May 31, 2012 Author Report Share Posted May 31, 2012 Yeah, that's sorted. It's all progress. Oil return is now leaking too. So will fix that today and then try again. It might be due to old fuel, or not enough fuel in the tank. But I think u can only fill 2 cans at a time... Link to post Share on other sites
jims13 6 Posted May 31, 2012 Report Share Posted May 31, 2012 I should have also said, that no ecu tuner can offer support if yoivdo not have a working obd port. It really is a must do. And will save you time and money , when diagnosing anything on the car. Link to post Share on other sites
VIW28 29 Posted May 31, 2012 Report Share Posted May 31, 2012 ^^ This!Did you get an OBD port to install yet? Link to post Share on other sites
michael5556 247 Posted May 31, 2012 Author Report Share Posted May 31, 2012 No not yet. Still looking. Link to post Share on other sites
craggsy 91 Posted May 31, 2012 Report Share Posted May 31, 2012 I my have a obd2 port in my old vr. I can check Link to post Share on other sites
michael5556 247 Posted May 31, 2012 Author Report Share Posted May 31, 2012 Yeah please mate. Link to post Share on other sites
craggsy 91 Posted May 31, 2012 Report Share Posted May 31, 2012 No probs. should still be light when I get home. I'm assuming you will need as much wiring as possible Link to post Share on other sites
michael5556 247 Posted May 31, 2012 Author Report Share Posted May 31, 2012 Yeah please. I have some spare wiring so will be able to wire it up. Thanks guys. Link to post Share on other sites
craggsy 91 Posted May 31, 2012 Report Share Posted May 31, 2012 No luck fella. Thats the only bit of dash trim i cant find and cant see the socket anywhere. Link to post Share on other sites
michael5556 247 Posted May 31, 2012 Author Report Share Posted May 31, 2012 Don't worry about it. Will keep looking. Link to post Share on other sites
sedge 7 Posted June 1, 2012 Report Share Posted June 1, 2012 You can go down a scrap yard and grab a port out of any vw from mid 90's. Hopefully there should be something down the local scrappy! Link to post Share on other sites
michael5556 247 Posted June 1, 2012 Author Report Share Posted June 1, 2012 Yeah will have a look. Thanks. Link to post Share on other sites
michael5556 247 Posted June 2, 2012 Author Report Share Posted June 2, 2012 Not having much look this week! Turbo oil feed decided its going to have a small hole in. Now my ignition barrell has decided to not work lol going to wire up the starter solenoid to a switch tomorrow and see if that's works. Link to post Share on other sites
ashmk3 0 Posted June 2, 2012 Report Share Posted June 2, 2012 It could of been your ignition barrel after all this then. Mine went funny on my mk2. Turned over but wouldn't for then some days it would then use be stranded in a car park. Then changed it and all was fine. Link to post Share on other sites
michael5556 247 Posted July 9, 2012 Author Report Share Posted July 9, 2012 Right, no luck so far. It runs but very hot. Got rid of the dump valve for now. Fuel pressure is at 4bar. Do I need more than a 1/4 tank with the Bosch 044?What air fuel ratio does every run? It's on around 12-13 on idle. Too low? Link to post Share on other sites
jims13 6 Posted July 9, 2012 Report Share Posted July 9, 2012 fpr depends on ecu mapper, united motorsport use the stock 3 bar , as will the old c2 stuff.. stealth i believe map what you have in. what issues are you having Link to post Share on other sites
michael5556 247 Posted July 9, 2012 Author Report Share Posted July 9, 2012 It will idle for around 20 seconds then go lean and just stall. Randomly. Also it's not boosting and I have a suspicion that the wastegate is stuck open? The turbo is also making a rattling noise which worries me a bit. It starts now though. I have a video of the afr gauge. Give me a minute... Link to post Share on other sites
michael5556 247 Posted July 9, 2012 Author Report Share Posted July 9, 2012 http://i1085.photobucket.com/albums/j438/michael5556/42720f63.mp4There you go. Link to post Share on other sites
UnitedMotorsport 55 Posted July 9, 2012 Report Share Posted July 9, 2012 Sounds like at least one cylinder is low on compression too. Link to post Share on other sites
michael5556 247 Posted July 9, 2012 Author Report Share Posted July 9, 2012 Is that due to the low comp pistons or it's just knackard? Link to post Share on other sites
ashmk3 0 Posted July 10, 2012 Report Share Posted July 10, 2012 Do a compression test, that way you'll know if it's across all of them (due to low comp pistons) or only one knackered . Did you change the gasket etc what bolts are in there? Link to post Share on other sites
michael5556 247 Posted July 10, 2012 Author Report Share Posted July 10, 2012 Yeah I will do one later towards the end of the week. The gasket is reasonably new and it has arp head and rod bolts. I might take the head off seeing as they are re usable bolts and have a look what's going on down there. See what the compression test brings back. Link to post Share on other sites
michael5556 247 Posted July 12, 2012 Author Report Share Posted July 12, 2012 Will try and put it back down to 3 bar today and see if that makes any difference... Link to post Share on other sites
michael5556 247 Posted July 14, 2012 Author Report Share Posted July 14, 2012 Got it running mint on around 3.2 bar. Left it. 20 minutes later it spat its dummy out and was running very lean to the point where it would stall. After some research it turns out that the c2 chip doesn't need the lambda sensor plugged in on some older versions of software? Will try this today. Link to post Share on other sites
