flipb 0 Posted May 19, 2012 Report Share Posted May 19, 2012 Hi guys. Don't suppose anyone can make a suggestion where I can find some detailed guidance on removing the heater matrix? I have got as far as getting the dash out and have got the heater motor out but I am struggling to identify the correct bolts to undo in the engine compartment. The way I am going, the front of the cr will fall off if I losen any more bolts on the bulkhead :-)If anyone knows where I can find some pictures of the steps or can give some guidance, it would be really appreciated. I believe that I have still got to get out the motor housing but i dont know which bolts in the engine bay hold it in place. Cheers in advance! Link to post Share on other sites
cabrioman 6 Posted May 19, 2012 Report Share Posted May 19, 2012 there is a one behind the heat sheild on the bulk head behind a flap and one near the ABS pump there is a guide in the premium members section .... Link to post Share on other sites
flipb 0 Posted May 20, 2012 Author Report Share Posted May 20, 2012 Many thanks. I joined up last night and it's got me 95% there. Trouble seems to be that I have air con and looking at what I have here, if I disconnect the pipes in the engine bay, I will probably need to re gas it? Link to post Share on other sites
aminder 4 Posted May 20, 2012 Report Share Posted May 20, 2012 You should be able to just undo the two hoses going into the heater matrix and with dash removedundo the 4 screws holding the heatermatrix in place in the complete fan unit and pull up and replace.You shouldn't need to undo any other bolts in the engine bay apart from two to remove the dash.Sounds like you trying to remove the whole heating/fan unit Link to post Share on other sites
