ryanmac 0 Posted May 12, 2012 Report Share Posted May 12, 2012 Hi all After seeing another forum member using a fiat bravo side fill radiator I decided this was the option for me as my old rad and coolant tank was knackered plus the tank fouled my strut brace. After fitting the fiat rad on new mounts the cross beam the old rad sat on now fouls the lower coolant tank house. As I have used new mounts and also relocated the power steering pump cooler this cross beam seems to play no part now so I was wondering if I can remove it completely. The engine sits on its on beam and will still keep the strength so will I get away with binning it.....Also if I had to fit the fan switch into the rad hose would it be better on the top coolant hose or bottom coolant hose....Cheers Ryan Link to post Share on other sites
FishWick 21 Posted May 14, 2012 Report Share Posted May 14, 2012 Eh? Fiat radiator and binning the radiator support panel? What are you crazy kids up to?!?Pics might help! Link to post Share on other sites
