does my car run a 4 bar or 3 bar fuel pressure regulator??
as title have a 1992 obd1 golf vr6. will it run a 4 bar or 3 bar fuel pressure regulator as tony couldnt remember off the top of his head. many thanks guys.
weird as mine has a 4 bar regulator then?? so it should be a 3 bar one i need?? trying to sort out my horrible idling.
Can't imagine it causing any issues to be honest.
Tried all the usual stuff like cleaning ISV, throttle body? Could be that your ISV is duff? Or MAF? (does it run better disconnected, the same or worse?) checked ECU fault codes, vaccum leaks? Does it idle better once upto temp?
Tried all the usual stuff like cleaning ISV' date=' throttle body? Could be that your ISV is duff? Or MAF? (does it run better disconnected, the same or worse?) checked ECU fault codes, vaccum leaks? Does it idle better once upto temp?
done everything mate cleaning wise, had tonyvrt pop over earlier with vag-com and no fault codes! just a case of replacing stuff to see if it works better!
