hi guys and girls i got a problem with my vr
i left the car sitting on my driveway for couple of months, i tried to start it the other day but i wont turnover, after some research i found out that it awas the alarm, so i had a guy from a alarm comany come and take the alarm and imbolizer out, so i put a new batterey and tried to start but nothing, after speaking to a couple of people i found it was the throttle position sensor, so i cahnged and tried to start but nothing,so i need help and advice
first things first. does the engine turn over? if no. your problem lies between igntion switch and startermotor.
if it DOES turn over, do you have a spark? if yes. check all plugs to make sure each one is getting a spark. if yes, check injectors are pulsing. if yes again then it will start . if no spark. make SURE your alarm was removed properly. after that, you need vag com or a qualified mechanic to come and check it.
