filtee 0 Posted December 21, 2011 Report Share Posted December 21, 2011 Fitted a used one today as my old one was leaking. The new one works as i can hear it running when the ignition is on. When i take the keys out it stops. Isnt the whole point of it to run afterwards? Link to post Share on other sites
VR6Pete 1,456 Posted December 21, 2011 Report Share Posted December 21, 2011 It will, but only when the car is upto temperature.... how long did you leave it running for? Link to post Share on other sites
filtee 0 Posted December 21, 2011 Author Report Share Posted December 21, 2011 I thought it was maybe that. Ive been using it all day and got it well upto temp and ive not heard it. Link to post Share on other sites
legvw 0 Posted December 21, 2011 Report Share Posted December 21, 2011 Could be several things. Fan control module, yellow coolant temp sensor or fuse? Link to post Share on other sites
filtee 0 Posted December 21, 2011 Author Report Share Posted December 21, 2011 But wouldn't they cause it not to work at all? Link to post Share on other sites
Vw_owner 1 Posted December 21, 2011 Report Share Posted December 21, 2011 prety sure my corrado and my golf vr6 is the same {both obd1}, the fans still come on/off when up to temp, and still work as they should once ign is off, im prety sure the aux pump doesnt after run on both of mine aswell Link to post Share on other sites
cbmotorsport 0 Posted December 27, 2011 Report Share Posted December 27, 2011 pump should run on for a while weather it is hot or cold, mine used to ,and 2 other friends cars also do it . :so it could be a faulty fan control module . Link to post Share on other sites
filtee 0 Posted December 27, 2011 Author Report Share Posted December 27, 2011 Is that the fusebox thing under the water reservoir? I checked the fuses in that yesterday and all ok. Link to post Share on other sites
cbmotorsport 0 Posted December 29, 2011 Report Share Posted December 29, 2011 thats it. its actually a control module that runs the fans and the auxilliary pump. the fuses are for the fans. but it may be the module its self that is faulty as the pump should run for 10 minutes weather its hot or cold. Link to post Share on other sites
filtee 0 Posted December 30, 2011 Author Report Share Posted December 30, 2011 Hmm ill see if i can try one somehow. I know theres loads of different types isnt there. Link to post Share on other sites
