Dizzy 0 Posted October 27, 2011 Report Share Posted October 27, 2011 Hi my vr6 will now start but wen rev it up it lumpy and splutery which it won't even pull of with it, î Link to post Share on other sites
filtee 0 Posted October 27, 2011 Report Share Posted October 27, 2011 Maf? Link to post Share on other sites
cabrioman 6 Posted October 27, 2011 Report Share Posted October 27, 2011 sounds like a misfire ..... have you had the leads off ??? if so are they in the correct order ??!! what condition are the plugs, leads and coil pack in .... Link to post Share on other sites
Dizzy 0 Posted October 27, 2011 Author Report Share Posted October 27, 2011 Maf?Hi iv disconnected maf and it made no difference weather it should of and that says there something wrong with it I'm not sure thanks Link to post Share on other sites
Dizzy 0 Posted October 27, 2011 Author Report Share Posted October 27, 2011 sounds like a misfire ..... have you had the leads off ??? if so are they in the correct order ??!! what condition are the plugs' date=' leads and coil pack in ....[/quote']Hi all leads plugs and coil pak all look new only had car for a week,it started wen wife thought she ran out of fuel she got bak to me and I took it to put fuel in which kept stalling got it home and died half hour l8r got it started ticks over fine but bag of shite revin it up it won't pull of î˜ Link to post Share on other sites
MJ Vr6 79 Posted October 28, 2011 Report Share Posted October 28, 2011 Disconnect Coolant Temp Switch and see what happens. Link to post Share on other sites
Dizzy 0 Posted October 28, 2011 Author Report Share Posted October 28, 2011 Disconnect Coolant Temp Switch and see what happens.Hi feel a bit daft but we're the coolant temp switch thanks Link to post Share on other sites
Daverse 175 Posted October 28, 2011 Report Share Posted October 28, 2011 If the maf disconnected doesnt make a difference, then its probably that mate Link to post Share on other sites
MJ Vr6 79 Posted October 28, 2011 Report Share Posted October 28, 2011 Hi feel a bit daft but we're the coolant temp switch thanksNo need to feel daft fella, everyone here to help..Look at the engine, right side of block below inlet, you will either see 2 or 3 colours, Yellow Brown and Blue, if your car has no A/C then its only 2 colours, think its Brown and Blue, Disconnect the blue, start car and see what the outcome is, does it make things worse, or same?? Link to post Share on other sites
Dizzy 0 Posted October 28, 2011 Author Report Share Posted October 28, 2011 Ok I've tried that and it still runs the sameHi feel a bit daft but we're the coolant temp switch thanksNo need to feel daft fella' date=' everyone here to help..Look at the engine, right side of block below inlet, you will either see 2 or 3 colours, Yellow Brown and Blue, if your car has no A/C then its only 2 colours, think its Brown and Blue, Disconnect the blue, start car and see what the outcome is, does it make things worse, or same??[/quote'] Link to post Share on other sites
MJ Vr6 79 Posted October 28, 2011 Report Share Posted October 28, 2011 Change Sensor pal.Have you anyone with VAGCOM near you..? Link to post Share on other sites
Dizzy 0 Posted October 28, 2011 Author Report Share Posted October 28, 2011 Change Sensor pal.Have you anyone with VAGCOM near you..?Unfortunately no,iv just took air filter out and run without and it run better Link to post Share on other sites
MJ Vr6 79 Posted October 28, 2011 Report Share Posted October 28, 2011 Dude, I wonder if that has ran a tad better as you unplugged the CTS and put back on again....Hmmmmmmm??? Link to post Share on other sites
Dizzy 0 Posted October 28, 2011 Author Report Share Posted October 28, 2011 It did rev better wiv airfilter out and maf sensor connected but not enough to drive it Link to post Share on other sites
filtee 0 Posted October 28, 2011 Report Share Posted October 28, 2011 Is there no-one local to you with a vr with same obd?If so, just get them to call round and try their maf. 2 minute job. At least if its not that (which it probably will be) you can rule it out. Link to post Share on other sites
Dizzy 0 Posted October 29, 2011 Author Report Share Posted October 29, 2011 No1 local that I no of that has vr got AA out but Thay not got the rite plug to test it he only got 16 pin , but he reckons it maf so do I take gamble and spend the £65 on new maf Link to post Share on other sites
filtee 0 Posted October 29, 2011 Report Share Posted October 29, 2011 Have ya tried cleaning the maf youve got? If not, try it. Theres loads of info onhere about what to use/do. Link to post Share on other sites
Dizzy 0 Posted October 29, 2011 Author Report Share Posted October 29, 2011 Have ya tried cleaning the maf youve got? If not' date=' try it. Theres loads of info onhere about what to use/do.[/quote']Hi thanks for info I bought new maf today and car running sweet again î— Link to post Share on other sites
filtee 0 Posted October 30, 2011 Report Share Posted October 30, 2011 Cooooooooooooooooollll Link to post Share on other sites
