I was gonna replace my coolant today as I have no idea when it was last done. I am reading from a mk3 gti haynes manual, but I'm not sure which hoses to disconnect as they look slightly different. I want to flush both the rad ant the engine. Can anyone give any helpful pointers?
i personally wouldnt bother cos youre introducing a lot of chances to create leaks in the t-stat housing and water distribution system and replacing all that is a front off job and about £200 worth of bits.
Ive had good success with holts speedflush, which you empty into the coolant system before the job,
Run the car for about 40 miles or 48 hours getting up to temp to circulate the whole system, then empty and flush with straight water, circulate that when up to temp for 5 miles or so then empty and fill with fresh coolant, removed a lot of sh!t from my system
