Finally I'm done the car is running and am I glad it's finished and I forgot to mention a braided brake hose was also damaged and was replaced. The car has a problem tho. When I am on the motor way in 5th at low revs when I try to accelerate the car misfires and I get popping in the inlet?? Does anyone have a clue on what this could be. It's idles around 920 is this normal thanks.
  • Replies 58
mine normaly idles around 700,but can idle at around1000, has it been raining? lol my corrado is absolutley terrible for getting a damp MAF plug, and when its damp it'll idle high and can run crap, squirt wd40 or other water repelant in the MAF connection plug,other then that make sure your ht leads are seated properly, hope this helps,,
Today I checked codes and checked all breather pipes were ok and every thing was fine. A few codes came up but nothing corresponding to the misfire issue. Tommorow I will take the rocker cover off and check the timing. What symptoms would I get if the timing was off ??
