oldmandon 1 Posted February 23, 2011 Report Share Posted February 23, 2011 As the title says, Where is it?I have a new thermostat to go in, have had a very quick squint but was unable to locate the housing.....yeah I know.... dumbo.......So, front or rear left or right as you look in the bay (from the front obviously) Also, what needs to come off to get good access to itThanks in advance Link to post Share on other sites
chief ka kar 0 Posted February 23, 2011 Report Share Posted February 23, 2011 As you look in your engine bay on the right hand side under the inlet manifold. You will see a plastic mold type cover which holds 3 sensor sin it if you have a/c or 2 if not.I remove my coil pack which is just 4 allen bolts remove them then just lift out of the way no need to removed plug leads so i could see the allen bolts for the thermostat hosuing Link to post Share on other sites
VR6Nat 9 Posted February 23, 2011 Report Share Posted February 23, 2011 heres a digram of the houseing and the settings... Link to post Share on other sites
chief ka kar 0 Posted February 23, 2011 Report Share Posted February 23, 2011 Hope this helps Link to post Share on other sites
oldmandon 1 Posted February 23, 2011 Author Report Share Posted February 23, 2011 Thanks for the replies, now I can see why I couldn't see it straight away, not the most accessible, not the worst either, just looks nothing like a "normal" thermostat housing!!!!!!!!!! Link to post Share on other sites
