rochford 0 Posted August 3, 2010 Report Share Posted August 3, 2010 Hi,I've got a problem with my aircon and radiator fans. When I run the engine, and with the bonnet up I can hear the aircon pump start to opperate, but the radiator fans stay off. If I leave the engine to run hot, the temp dial goes up and the radiator fans switch on at top wack.I thought it was an air/gas problem so took it to an aircon specialist. He tested it but said it was because the radiator fan/s were not cutting in early enough. He seems to think that it is the radiator fan motor that is faulty, because it doesn't run at "level 1 or 2" only cutting in at level 3 - the maximum. He says it's not the relays,but reading through some of the threads I'm not so sure. Any suggestions would be appreciated. Dave Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 its the air con switch in thermo housing I beleive that controls speeds 1 and 2 Link to post Share on other sites
craggsy 91 Posted August 3, 2010 Report Share Posted August 3, 2010 should be the brown plug....try unplugging it and see if ot still does same thing Link to post Share on other sites
rochford 0 Posted August 3, 2010 Author Report Share Posted August 3, 2010 Thanks for suggestion, will try removing brown connector tomorrow. Will keep you informed. Link to post Share on other sites
