Drizz 0 Posted July 26, 2010 Report Share Posted July 26, 2010 I was looking for rear Goodridge hoses for my VR, and all i could find listed were mk4 calipers on a mk3 hoses. So therefore is this a common upgrade?Tell me more??? Link to post Share on other sites
craggsy 91 Posted July 26, 2010 Report Share Posted July 26, 2010 yes...they are made of ally so dont rust as easy...unless im mistaken that is Link to post Share on other sites
Drizz 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 With standard VR discs? Link to post Share on other sites
craggsy 91 Posted July 26, 2010 Report Share Posted July 26, 2010 yep Link to post Share on other sites
finny 0 Posted July 27, 2010 Report Share Posted July 27, 2010 I have put Mk4 calipers on my VR and here is what I know/ did....You use standard size discs and the original Mk3 caliper carriers. My 2nd hand Mk4 calipers came with its carriers. You might be able to use these Mk4 rear carriers if your were prepared to angled grind to fit and also cut the metal dust shield to fit. Much easier just use the Mk3 carriers. The brake hose fitting on the Mk4 caliper is a banjo type fitting (So caliper, copper washer, hose, copper washer and then the screw valve fitting on top). The Mk3 brake hose that goes into a Mk3 caliper is just a screw in type fitting. (dunno tech term!) thats why you need these 'conversion' type hoses.Remember to clean and throughly lube the slider pins in the calipers before hand. Use a brake rewind tool to push back the piston. Bleed brakes in usual way etc. Amongst all that I replaced with new discs, pads, bearings etc and hopefully won't have to touch the rear brakes for a long while. Couldn't fit the brake pad squeal shims and brakes are not squealling anyway.Currently I am running Goodridge braided hoses at the rear and standard front hoses. Car has no detrimental effect but ideally looking to upgrade the fronts with braided hoses. Link to post Share on other sites
Drizz 0 Posted July 27, 2010 Author Report Share Posted July 27, 2010 Thanks for the info fella! Link to post Share on other sites
