Antihero1981 8 Posted April 24, 2010 Report Share Posted April 24, 2010 HI , put in some BKR5EKUP spark plugs in and i dont think they are gapped correctly as car spluttering now over 3k revs , been told the normal setting is 0.7 as standard but supercharged should be running 0.22 gap , is that correct?tried search and did not get a good enough answer , car off road at moment...need to get it running asapthanksobd2 v9 Quote Link to post Share on other sites
craggsy 91 Posted April 24, 2010 Report Share Posted April 24, 2010 I run BKR7E in my charged VR.....and they are gapped to .24 Quote Link to post Share on other sites
Antihero1981 8 Posted April 24, 2010 Author Report Share Posted April 24, 2010 thanks dude , looks like i will pulling them out tomorrow to check it out..... Quote Link to post Share on other sites
Antihero1981 8 Posted April 25, 2010 Author Report Share Posted April 25, 2010 well changed plugs back after a mission and car runs fine, but there is a big difference between the spark plugs new vs old , the old ones have a really small gap while the new ones are gapped 0.24 , the the prongs on the old ones are longer and have 3 while the new ones are shorted and only have 2.... Quote Link to post Share on other sites
Rikki 2 Posted April 26, 2010 Report Share Posted April 26, 2010 I run BKR7E in my charged VR.....and they are gapped to .24That gapped as they come mate? Quote Link to post Share on other sites
craggsy 91 Posted April 26, 2010 Report Share Posted April 26, 2010 Had to gap em to that mate Quote Link to post Share on other sites
Antihero1981 8 Posted April 26, 2010 Author Report Share Posted April 26, 2010 mine look the correct gap but compared to old ones the gap looks way to big....they are different spark plugs , worked staright away when i put old ones back in... Quote Link to post Share on other sites
Rikki 2 Posted April 26, 2010 Report Share Posted April 26, 2010 Had to gap em to that mateCool. Thanks. Quote Link to post Share on other sites
MJ Vr6 79 Posted April 27, 2010 Report Share Posted April 27, 2010 HI ' date=' put in some BKR5EKUP spark plugs in and i dont think they are gapped correctly as car spluttering now over 3k revs , been told the normal setting is 0.7 as standard but supercharged should be running 0.22 gap , is that correct?tried search and did not get a good enough answer , car off road at moment...need to get it running asapthanksobd2 v9[/quote']Try FR7KPP33. Quote Link to post Share on other sites
Gazbarber1982 3 Posted May 8, 2010 Report Share Posted May 8, 2010 Im running BKUR6ET-10. Apparently they are better for the vr as they perform better when hot. They are for the 2.0 16v gti. Icould be well wrong but i've never really had a problem with them and they're factory set at .040" but i'm more than willing to try the others. I'm assuming the other measurements are in inches rather than mm / cm?!? Quote Link to post Share on other sites
goonersteve 0 Posted August 10, 2013 Report Share Posted August 10, 2013 Just searching through various forums trying to work out correct gapping measurement for my VR, but I am finding conflicting info! Got a stage 1 supercharger and just bought some NGK BKR7E plugs. I know Craggsy says above that he gapped his to 0.24 - was this using imperial units (so therefore 0.61mm in metric units)? Also, what stage charger was this on and does it make a difference to the recommended gap measurement? Help please!! Quote Link to post Share on other sites
Antihero1981 8 Posted August 10, 2013 Author Report Share Posted August 10, 2013 dont think the stage would make any differance , have you measured them now? if so what are they? have you tried putting them in and running them? Quote Link to post Share on other sites
goonersteve 0 Posted August 10, 2013 Report Share Posted August 10, 2013 I was just thinking that perhaps if it's only stage 1, may not want the gap quite as small as something running bigger boost. Not measured them yet, or fitted them, as I wanted to check first before playing around with them too much. Quote Link to post Share on other sites
UnitedMotorsport 55 Posted August 10, 2013 Report Share Posted August 10, 2013 I know Craggsy says above that he gapped his to 0.24 - was this using imperial units (so therefore 0.61mm in metric units)? I dont think he was talking imperial units at 0.24" as that is over 6mm! Quote Link to post Share on other sites
Lukey. 381 Posted August 10, 2013 Report Share Posted August 10, 2013 Maybe .024" Quote Link to post Share on other sites
craggsy 91 Posted August 10, 2013 Report Share Posted August 10, 2013 I can't remember what I gapped em to now TBH.Jim would know Quote Link to post Share on other sites
leespiro 9 Posted July 1, 2015 Report Share Posted July 1, 2015 hi all what gap should the FR7KPP33 spark plugs be on the vr6 12v turbo thanks Quote Link to post Share on other sites
ssaunders 199 Posted July 4, 2015 Report Share Posted July 4, 2015 I run BKR7E in my charged VR.....and they are gapped to .24Are they bkr7e 11? Only bkr7e's I can find are for a mid nineties Jag? I'm guessing it's just a revision number? Got 6 of the jag ones for £13 delivered from the bay.What's the lifetime? Been reading and people are saying 6-10k at most?Sorry to jack S Quote Link to post Share on other sites
c00k 435 Posted July 5, 2015 Report Share Posted July 5, 2015 (edited) BRK7E 11, are the same as BRK7E... just the 11's have bigger gap. So if your going to gap them with feeler guage, your better off the BRK7E as it a smaller gap to start with.If your not gapping them BRK7E with be ok with standard gap. BRK7E 11 will have to bigger gap for forced induction. So they will need gapping down. Edited July 5, 2015 by c00k Quote Link to post Share on other sites
c00k 435 Posted July 5, 2015 Report Share Posted July 5, 2015 (edited) http://pages.ebay.com/link/?nav=item.view&alt=web&id=221396717181&globalID=EBAY-GB Looks for NGK 6097 they're BRK7E. Edited July 5, 2015 by c00k Quote Link to post Share on other sites
