Ben Seabrook 4 Posted March 8, 2010 Report Share Posted March 8, 2010 With the nice sunshine we had the other day I decided to open my sunroof, it only goes halfway back and then when you press the close button it slides back but then goes up and finishes half open ! is this the motor gone or is there a way to reset the close position ? Cheers peeps Link to post Share on other sites
Ian_rogers 0 Posted March 8, 2010 Report Share Posted March 8, 2010 Are u able to find a way of closin it now or is it stuck open? Link to post Share on other sites
Ben Seabrook 4 Posted March 8, 2010 Author Report Share Posted March 8, 2010 no I have managed to close it Link to post Share on other sites
Ian_rogers 0 Posted March 8, 2010 Report Share Posted March 8, 2010 Ah ok, I could have helped get it closed, it's peoably just the button stickin but I'm not an expert lol Link to post Share on other sites
Ben Seabrook 4 Posted March 8, 2010 Author Report Share Posted March 8, 2010 dont think so mate as it stops when you take your finger of it ! anymore ideas peeps ? Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Author Report Share Posted March 9, 2010 anyone please help ? Link to post Share on other sites
VR6Nat 9 Posted March 9, 2010 Report Share Posted March 9, 2010 im guessing its got something to do with electrics.... wires n that... :) lol Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Author Report Share Posted March 9, 2010 ha ha thanks !!! I might just change the motor over and see what happens but that means I have to take the headlining out :( is there no way to change or reset the stop position ?? Link to post Share on other sites
VR6Nat 9 Posted March 9, 2010 Report Share Posted March 9, 2010 No seriously have you tried removing the switch and cleaning it?What happens when you leave it open and try shutting it using the key?? does it work ok then?? if so its def the switch. Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Author Report Share Posted March 9, 2010 nope, when you press the close switch on the panel it closes then opens and stops about an inch up, if the car is closed and you press the alarm button it again rises up about an inch so you have to pull it back by that much and then press the alarm button so when it moves it then ends up in the correct closed position !! Link to post Share on other sites
VR6Nat 9 Posted March 9, 2010 Report Share Posted March 9, 2010 ahhh... then its not the switch... what a bugger.... might be the motor then, what about the sunroof general, have you given it all a good clean?? unplugging any plgs and replugging it... all worth a go before ripping the motor out... a good smack often helps to shake things into action too Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Author Report Share Posted March 9, 2010 yeah cant see anything obvious but will have another look later if not taking a hammer to it is very tempting !! Link to post Share on other sites
VR6Pete 1,455 Posted March 9, 2010 Report Share Posted March 9, 2010 its an easy job removing the motor - did you have one in your old VR, ben?Pete Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Author Report Share Posted March 9, 2010 yes mate that's what I am thinking about doing just swopping them over to see if that works Link to post Share on other sites
legvw 0 Posted March 9, 2010 Report Share Posted March 9, 2010 Could the motor have jumped a few cogs, don't really know how they work but if you can take the motor out, use the switch to open it until the motor stops, thenuse the switch to put the motor back in the shut position, then bolt the motor on it should be back to normal? (if that makes any sense!!!) Link to post Share on other sites
Ben Seabrook 4 Posted March 9, 2010 Author Report Share Posted March 9, 2010 mmm well have take the old whole control unit and motor from the old one so will have a look mate - I hope it's that as that makes sense and am sure I could do that Link to post Share on other sites
