Mr oemforyou 0 Posted February 24, 2010 Report Share Posted February 24, 2010 hi new on here would quickly like to say how good the site is and how friendly everyone seems to be im looking at buying a corrado vr6 and just wanted to know the things that have to be checked when buying one of these cars from bodywork,mechincal and engine wise any help would be massively appreciated,also wondering what the around town mpg is on these cars are.....thankyou to anyone who takes there time to help me cheers chris. Link to post Share on other sites
dman78 1 Posted February 24, 2010 Report Share Posted February 24, 2010 hey mate welcome,took time out to read your thread,i find that it's the same as running a 1.8t quattro round town then again it depends on how heavy your right foot is,hope this helps Link to post Share on other sites
VR6Nat 9 Posted February 24, 2010 Report Share Posted February 24, 2010 Hello and welcome to the site!! :)Corrados are gorgeous cars, all i will say before anything is dont rush! There are a lot of good ones out there but you have to do some hunting... here's a Corrado specific buyers guide:Good luck with your search! (oh and you should expect to get between 20 and 32MPG depending on how you drive)Corrado Buying GuideBody & ExternalCheck for accident damage around inner wings and the boot floor, including seams.The rear panel (above the spare wheel as you look in the boot) has a VAG sticker which gives all model information, if this has gone, the car may have had rear end damage and been rebuilt/resprayed.Rusty creases in the inner part of the front wings may mean the car has had some front end damage/repair.Above rear bumper - check that the two vertical 'seams' at each side of the rear panel are perfect, straight and even, with no bubbling/rust coming through (possible evidence of poor rear end damage repair).Also look for rust on the chassis and under the bonnet and door sills and check the valance under/behind the front bumper/lower spoiler for rust.Check body for:ScratchesDentsRustMisaligned panels (inc doors, bonnet, boot)Door handles are stiff. Can be replaced with Passat rear handles (de-locked) for around £10 each or genuine Corrado handles for approx £55 each!Stone chips on the bonnet are quite common. Although this can just be an indication of motorway driving.For info:- Bonnet cross sections:Early style ------______------Late Style ____----------____Lights for cracks including spots.Headlights for early models are £60+vat and £99+vat for later complete units.Headlight glass is 22.50+VAT from Euro Parts for both early and late modelsFogs from GPC will cost approx £50 for early style and approx £75 for later styleIndicators are about £50 new from VW, but can be had from scrap yards more commonly than "good" fog lamps. 2nd hand they seem to fetch about £25 the pair.More details on the differences between early and late specs can be found at the bottom of this pageChassis plates - check the VIN plate on the cross member at the back of the engine bay matches the log book and the sticker inside the bootColour code ("mailshot" size sticker on the inside of the rear panel with the relative colour code or an orange-red smallish sticker on the inside of the o/s/f wing) & also a sticker insider the drivers side door pillar.Wipers are notoriously poor – possible remedies include modding the existing setup or using Lupo wipers, which would be a bonus if already doneColours/CodesSee the list at the bottom of this page for colour codes and detailsVW's (amongst others) reds are quite infamous for fading/going pink. A good check to see if the colour can be recovered is to rub a wet finger on the paint – if it regains some of it's colour, the odds are that it can be recovered with cutting compound treatmentInteriorLook out for ripped/worn/saggy seat bolstersSunroof – does it tilt and slide. Any scratching to the paint on the external side of the sunroofPassat glass sunroof can be used as a direct replacementCheck for damp carpets in the footwells – could be due to heater matrix or could need new inner door membranesIf its passenger side (RHD) check that leaves, pine needles etc have not blocked the drains by the bulkhead, as in hard rain the bulkhead area can fill up and overflow into the ventilation intake. Cheap fix!Leather is a sought after extra. Available in Black, Cream, Grey [any more?] and on the Campaign model, Brick-Red (but you'll be lucky to find one of the 6 available Campaign interiors or cars.Check the headlight switch action is smooth and accurate - they run warm and this can make the plastic brittle. If its notchy or wobbly, it could be about to snap inside and a new one is expensive. Used one, less so, but rare. Alternative is a bottle of superglue and a quiet night in.First aid kit in centre arm-rest (if applicable) - can be replaced with other first aid kits for around £30Warning triangle in rear seat back (zipper at top) - can be bough from dealers for around £20Check that the ventilation control panel functions competely. The fan should work in all four positions and the "direction" dial should also work. For later (dial type panel) a replacement is over £200 and slider type panel used on early cars is no longer available from VWWheels & tyresKerbed alloysWorn tyres (especially uneven wear)Missing centre capsSigns that the wheels are fouling the archesCheck the condition of the spare wheel, and more importantly, that it has one! Also check that the jack, wheel-brace, spanner and screwdriver are presentAll 4 cylinder (2.0 8v, 1.8 16v, 2.0 16v and 1.8 G60) models have 4-stud hubs and all VR6's have 5-stud hubs.SuspensionListen for any knocking sounds from the suspension and check to see if there is any leakage from the dampers.Under rear wheel arches - look at shock absorber top spring plate, check for corrosion and ensure there is a gap between the plate the top of the strut spring sits in, and bodywork.A decent set of coilovers can be a plus point because if you intend to add them yourself, you will need to budget approx £500 for an average (price-wise) setup. VW did spend a lot of money developing the suspension, however, so finding a good standard setup is preferable (might be a sign of less 'spirited' driving as well).BrakesCheck handbrake. Lots of ‘clicks' to engage?Condition of disksWarped disks (brake judder)ABS – Should be included on all VR6 and 2.0 16V's (should also have traction control as well). Some later G60's had ABS. It was also an option on the other models as well.There should be an orange ABS light in the dash to the left of the driver (It has been known for cars with faulty ABS for the warning light to just be removed!!Start the car with your foot on the brake pedal – you should feel a pulse and the light should go out.If the light is permanently on, it could mean:ABS sensors might need cleaningABS sensors might need replacingBrake fluid level is lowABS control unit might need replacingBrake pedal sensor might need replacingIn general, if the light is on and it isn't one of the top 3 faults above, it could be an expensive thing to fix.An abs light that refuses to go out may also be due to a faulty ignition switch, or, heaven forbid, a faulty abs pump (expect to pay £750 for a reconditioned one - a new one is over a grand from the stealers)Check for seized rear brake calipers as this is a common fault (although easily rectified)EngineThe important thing with any engine is regular oil changes with decent oil.Also Check:Oil cap(mayo)Water (mayo)Oil filter (should be VW or Bosch)Timing belt (all belts when serviced) has been changed. (Excludes VR6's)Check oil level & colourEngine noise (tappets and knocking)Smoke from exhaustOil leaks – after a drive, check for any signs of oil leaks.Listen out for noisy fuel pumpsGearboxDifficulty engaging gears - mainly 2nd and 1st when coldExhaustAs with any car, check for any signs of the exhaust knocking/rubbing against the underside of the car or listen for any signs of the exhaust blowing (hole in the exhaust)The standard exhaust is heavy and runs close to the rear axle and so a knocking from the rear on dips/bumps might be fixed with new rubbersElectricsLights – Corrado lights are poor. An uprated headlight loom (can be made for £10 or bought for £50) would be a bonusHeater – does it function on all settings?Heated windows/mirrors/washer jetsMFA computer (check mileage), and that all functions work:Time, Miles traveled, Time elapsed, Average speed, Average MPG, Oil temp, Outside TempAlso check that the MFA is not flashing or that it doesn't rest itself once the ignition is turned off. Both are signs of clocking.Electric windowsElectric MirrorsRear spoiler – Does it work when standing and automatically when moving (45mph is the most common ‘raise' speed (should lower at under 10mph))Alarm/immobilizerDoes the stereo automatically switch on and off with the ignitionDrivingMake sure:Doesn't pull to the side when driving or breaking.Engine performs as it should (G60 – low down pull, VR6/16V's betterpull at higher revs)Any knocking, droning, clunking or any other noisesSqueaks from belts such as power steering beltCheck documentationLog book (No. of owners)Service receiptsDealer stamps in service bookCheck that the History corresponds with/backs up the mileageVR6 specific checksListen for any noise from the timing chain. Slight noise (rattle) can be acceptable.The guides and tensioner can need replacing once mileage approaches 80k+. £200 for parts alone and it's quite labour intensive as it can be worth doing the clutch whilst you're at it.VR6's generally have a rough idle. Check that the idle isn't overly erratic.Puffs of blue smoke on start-up (especially from cold) and over run. It could mean it has bore wear (time for a new block!), but it does mean you need the rings checking out.UK and Euro VR6 engines should have the ABV engine code which is the 2.9 litre engine. Golfs and USA VR6's (SLC for USA Corrado) are fitted with 2.8 litre versionsThe UK 'Storm' modelOnly from April 1995 onwards. Some were registered later than N-reg, however.Only Classic Green with beige leather or Mystic Blue with black leather250 of each colourThe log book will not identify the car as a StormColour coded grillBBS Solitudes Link to post Share on other sites
hvr6 88 Posted February 24, 2010 Report Share Posted February 24, 2010 welcome :-)http://the-corrado.net/forum/viewtopic.php?t=5004 Link to post Share on other sites
VR6Nat 9 Posted February 24, 2010 Report Share Posted February 24, 2010 Oh and it might be worth printing that to take with you when looking at one cuz you'll soon forget!! Also it is well worth becoming a Premium Member when you do find your perfect Corrado as there is many benefits like great discounts and a knowledge vault which is priceless when you have a problem... :) Link to post Share on other sites
nivag27 5 Posted February 24, 2010 Report Share Posted February 24, 2010 Great List Nat, as for mpg I get around 22 to 24 ish around town and 30, 31ish on a run and lets just say I dont worry how much petyrol I use;) Link to post Share on other sites
Mr oemforyou 0 Posted February 25, 2010 Author Report Share Posted February 25, 2010 Thankyou very much for all the advise yeah im looking around now for a corrado vr6 got upto £3000 to spend so hopefully will find something nice,if anyone see's or hears of any nice ones going any heads up on it would be very appreciated. so with some average driving i should see about 28-30 mpg ? are the vr6s much better on fuel than the g60? just out of curisoty which corrado with average driving is better on the old mpg? how many miles is considered fine for a vr6? i hear they are very strong engines is this true? roughly when do clutches need changing? is it worth upgrading not looking at doing much modding engine wise. thanks for any advice im sure u get asked this all the time thanks for the patience. Link to post Share on other sites
Knightrider 1 Posted February 26, 2010 Report Share Posted February 26, 2010 My boy has a VR6 Corrado. Standard apart from Jetex 2 box exhaust and Green Cotton air filter - sounds absolutey awsome. Handles like a god as standard. Amazing car. He needs to sell it as he is running an (amazing) new business in London and is not using it enough. Have a look at the business smallcarBIGCITY - http://www.smallcarbigcity.com - he is Oli. If you want one, go onto the website and give Oli a call. It is a cracker. Great colour. Link to post Share on other sites
