DaveMcK 0 Posted January 20, 2010 Report Share Posted January 20, 2010 If you were buiding a mk3 vr6 track car, what modifications would you consider making?i'm building a vento (obd1) and just thought i'd see if anyone has advice...its stock atm with a welded cage and 2 bucket seats.what suspension/break pads etc would people reccomend? Link to post Share on other sites
H13VYY 0 Posted January 20, 2010 Report Share Posted January 20, 2010 eibach anti-roll bars, top brand damping adjustable coilovers (hard setting), big brembo brakes with 15" wheels with top brand tyres i.e. eagle f1's. Link to post Share on other sites
ingham 5 Posted January 20, 2010 Report Share Posted January 20, 2010 http://z8.invisionfree.com/Northloop/index.php?showtopic=6913 Link to post Share on other sites
ingham 5 Posted January 20, 2010 Report Share Posted January 20, 2010 low temp thermostat helps on track also Link to post Share on other sites
aminder 4 Posted January 20, 2010 Report Share Posted January 20, 2010 eibach anti-roll bars' date=' top brand damping adjustable coilovers (hard setting), big brembo brakes with 15" wheels with top brand tyres i.e. eagle f1's.[/quote']Upgrade rear bar only (induces more oversteer) I did front and reverted as didn't like handling.Good set of coilys are def - I did first track day on hottuning ebay ones - beat the sh*t out of themGet in touch with diluxe on CGti he sold his mk3 and has a set lying around.Brembo brakes will help, but not really worth it if you not increasing power on car, get standard VAG discs (~£40 each on trade) and Mintex M1155's also run some racing fluid (I use Halfords one - took about 1 litre to bleed and fill system)As for Tyres you really should be looking for some proper track tyres R888's or full slicks (look around online, bay, ed38) and pick up a used set if you can't afford spankers.You will def get your use out of them, and will not let you down on the day when they super heat. Link to post Share on other sites
bungy 2 Posted January 20, 2010 Report Share Posted January 20, 2010 Nitrogen in your tyres, £2.00 a tyre and does not expand and contract as much as air when heated / cooled. Cheap track mod. Link to post Share on other sites
golfrabbit33 0 Posted January 20, 2010 Report Share Posted January 20, 2010 make it go really really fast Link to post Share on other sites
AJmk2 2 Posted January 20, 2010 Report Share Posted January 20, 2010 Get it set up by a proper alighnment company , can be like driving a different car. Link to post Share on other sites
Phat VR6 3 Posted January 21, 2010 Report Share Posted January 21, 2010 don't slam it. strip the fuck out of it.. more weight from the front to the back. spend £800 on coilovers. 16" rims (light as poss) good tyres. new or polly bushes. lower final drive. weld the turrets up/ seams... turbo or charger. list never ends tbf fella... dont take it to serious or it will do your head in lol Link to post Share on other sites
bungy 2 Posted January 21, 2010 Report Share Posted January 21, 2010 Get it set up by a proper alighnment company ' date=' can be like driving a different car. [/quote']http://www.centergravity.co.uk/ Link to post Share on other sites
ingham 5 Posted January 21, 2010 Report Share Posted January 21, 2010 ATS DTC rims are light mine are 5.8 kg each in 15 inch i have found that a diesel under tray helps at high speed also Link to post Share on other sites
