Pearsy47 1 Posted November 19, 2009 Report Share Posted November 19, 2009 Hi basicly when i changed me pipes over to the green samcos, air got into the system, i have been looking on this site and nothing really has been said apart from it could be head gasket gone!! which i ve check its not that. People have said to run it from cold with the cap off , and let it warm up and squeeze the pipes which when i squeeze the pipes it seems to let the water out then suck air back in !! which ain t good !! so im asking what else can i do !!! Link to post Share on other sites
VR6Pete 1,455 Posted November 19, 2009 Report Share Posted November 19, 2009 stick your blowers on... normally running on fast idle will pull the air through after a few minutes.is your radiator ok? not blocked? disconnect bottom hose, run water through it. Link to post Share on other sites
Pearsy47 1 Posted November 19, 2009 Author Report Share Posted November 19, 2009 yer i do stick the old blowers on i haven t bother to chedck the rad to see if its block i just hate those bloody clips lol !! what shall i do if the rad is clear ?? Link to post Share on other sites
McPikie 3 Posted November 19, 2009 Report Share Posted November 19, 2009 Car facing uphill (on on ramp). Header cap off, fill up. Squeeze pipes til no more going in. Then, fill 2l coke bottle with water (bottom cut off) and place into header tank. Hold in place. Gravity will force the water through where it wont run.Run car until fans come on. Don't they have bleed nipples anywhere?? Link to post Share on other sites
McPikie 3 Posted November 19, 2009 Report Share Posted November 19, 2009 I cant see this post due to work filtershttp://forums.vwvortex.com/zerothread?id=3942272 Link to post Share on other sites
Pearsy47 1 Posted November 19, 2009 Author Report Share Posted November 19, 2009 Car facing uphill (on on ramp). Header cap off' date=' fill up. Squeeze pipes til no more going in. Then, fill 2l coke bottle with water (bottom cut off) and place into header tank. Hold in place. Gravity will force the water through where it wont run.Run car until fans come on. Don't they have bleed nipples anywhere??[/quote']I ve been reading about and no one can find a bleed nipple so now im going to get cock bottle now lol and give that ago hopefully it works !!! Link to post Share on other sites
McPikie 3 Posted November 19, 2009 Report Share Posted November 19, 2009 I put heaters on number 3, on hot.and just feel the top hose to the rad and rad to see if they getting hot Link to post Share on other sites
Pearsy47 1 Posted November 19, 2009 Author Report Share Posted November 19, 2009 ah i know the top hose does get hot all of them do its just a bastard you see the little air bubbles going into the expansion tank !!! Link to post Share on other sites
VR6Pete 1,455 Posted November 19, 2009 Report Share Posted November 19, 2009 if you see bubbles going into the expansion tank, its definatly moving, albiet very slowly...Theres a bleed thingy on the front of the crack pipe AFAIK - well there is on mine, but its a not a VW crack pipe.... Link to post Share on other sites
