heard about a company called flo-flex...apparently very good value and do vr6 stuff but on research found them to be very hit n miss so be careful. I would personally just get powerflex you dont wanna buy others then find out you need to change them again in 6 months....wishbones are too much hassle for that lol!
like said Superpro are a qualtiy equivilent to powerflex and quite often cheaper by some way' date=' They are also ideal if you want adjustment as the bushes can come with eccentric centers,
I found powerflex to be cheaper for the Golf stuff though
yeah i think im gonna put together a custom set with the superpro eccentric centred and the other bits from powerflex that superpro dont make
well im about to put an order through priracing for the wishbone kit incl castor adjustable rear bushes, and a set of rear beam pivot bushes. i know it means i still need to find the crossmember bushes and rack bush seperate, but i wont be left with the ARB mounts when i fit eibachs
