TheMainManRob 0 Posted August 16, 2009 Report Share Posted August 16, 2009 Is there a coolent pump in the trottle body? Mine hums realy loudly when the ignition is switched on. Its not the coolent pump as thats unplugged.I'm trying to work out if my electric pump has died or the relay. Can I just connect the electric pump up to the battery to see if it runs or will this realy kill it?Gotta get this car back together before work tomorrow. (SN) Link to post Share on other sites
legvw 0 Posted August 16, 2009 Report Share Posted August 16, 2009 No coolant pump in the throttle body, the coolant just passes through. Where is the noise actually coming from? The pump? Link to post Share on other sites
TheMainManRob 0 Posted August 16, 2009 Author Report Share Posted August 16, 2009 No coolant pump in the throttle body' date=' the coolant just passes through. Where is the noise actually coming from? The pump?[/quote']The noise is coming from what feels like the inside the throttle body. Last about 20 seconds. The electric pump is unplugged. The electric pump is the one mounted on the ouside right of the engine with two hoses coming out of it right?UPDATE : Hard wired the pump to the battery and it didn't work so it must be FUBAR. Link to post Share on other sites
Rikki 2 Posted August 16, 2009 Report Share Posted August 16, 2009 Its the throttle body adjusting itself it buzzes for about 15-20 secs when you switch the ignition on?????? Link to post Share on other sites
TheMainManRob 0 Posted August 16, 2009 Author Report Share Posted August 16, 2009 Its the throttle body adjusting itself it buzzes for about 15-20 secs when you switch the ignition on??????That could be it then, Uber loud though, is that normal? Can only slightly hear it when the bonnet is shut and I don't notice it when i'm in the car. Link to post Share on other sites
