VR6Pete 1,452 Posted August 8, 2016 Report Share Posted August 8, 2016 23 hours ago, The Monk said: Found the sump plug has been leaking into the under tray, I'm guessing since I changed her oil the other month. Tried to tighten it up and found that the plug kept turning with little resistance. I'm guessing that's a new sump and another oil change. Rather fortunate that I've found lots of them on ebay. 12v at £40 24v at £50 My AYL £150 second hand...... how the hell does that work???!!!! Buy a drain pan off eBay. I paid a tenner for mine ?? Quote Link to post Share on other sites
VR6 Supercharged 104 Posted August 9, 2016 Report Share Posted August 9, 2016 Didn't do anything to my VR today, but tomorrow when i'm back from holiday i'll be fitting a new idle speed control valve an hopefully it'll fix the idling problem I have... VR6Pete 1 Quote Link to post Share on other sites
Vag-hag 147 Posted August 9, 2016 Report Share Posted August 9, 2016 My idle is playing silly burgers now too...... Isv cleaning time Quote Link to post Share on other sites
VR6 Supercharged 104 Posted August 10, 2016 Report Share Posted August 10, 2016 13 hours ago, Vag-hag said: My idle is playing silly burgers now too...... Isv cleaning time Did think of cleaning mine, but if it does'nt fix said problem I won't know whether valve is at fault or not? Hence fitting a new one, and then hopefully job done. If not then i'll move to the next bit... Quote Link to post Share on other sites
VR6Pete 1,452 Posted August 10, 2016 Report Share Posted August 10, 2016 14 hours ago, Vag-hag said: My idle is playing silly burgers now too...... Isv cleaning time 13 minutes ago, VR6 Supercharged said: Did think of cleaning mine, but if it does'nt fix said problem I won't know whether valve is at fault or not? Hence fitting a new one, and then hopefully job done. If not then i'll move to the next bit... Convert to OBD2 and do away with those pesky things! The difference between an OBD1 and OBD2 is totally worth it! Quote Link to post Share on other sites
Vag-hag 147 Posted August 10, 2016 Report Share Posted August 10, 2016 I'll pick your brains over weekend matey..... Will bring cider VR6Pete 1 Quote Link to post Share on other sites
VR6 Supercharged 104 Posted August 13, 2016 Report Share Posted August 13, 2016 On 09/08/2016 at 10:07 PM, Vag-hag said: My idle is playing silly burgers now too...... Isv cleaning time Well here's a small update for anyone that's interested. Fitted new idle speed control valve and connected the recirculation/blow off valve up on Thursday, started car and all seemed ok as ran car for 10 mins with no problems? Anyhoo, went to car today to take out for test drive, and yes revs where up and down again as before on extreme closer inspection it would appear there's a small but noticeable crack in the throttle body, so its time for throttle to come off for a closer look..... Quote Link to post Share on other sites
redvr6_girl 190 Posted August 16, 2016 Report Share Posted August 16, 2016 I brought her to the garage for a block test , and nearly had a heart attack over the quote price to repair her Saying that : any good reliable garages (close to) Braintree Essex recommended to replace head gasket ? (That's not pushing the 1k mark) Tia Quote Link to post Share on other sites
The Monk 50 Posted August 23, 2016 Report Share Posted August 23, 2016 On 8/8/2016 at 9:03 AM, VR6Pete said: Buy a drain pan off eBay. I paid a tenner for mine ?? Changing the oil again, even after a few thousand miles doesn't bother me. It's the fact that most cars I've bought tend to be expensive to rectify. More so the fact that the sump off the AYL in the carriers is so much more expensive than any other engine of the same pedigree, that, or I've done a crap job of locating sellers. Probably the latter. I've also started to have more of an issue with hot starting now. Turning off and on is starting to drop the success rate of removing the lumpy idle immediately after. VR6Pete 1 Quote Link to post Share on other sites
bennyk 1,238 Posted August 25, 2016 Report Share Posted August 25, 2016 Bought this Votex lip for £50 off eBay in 2 pieces then made it into one piece!Now to see if it can be persuaded onto a US bumper! Bealieboy, rich, VR6 Supercharged and 2 others 5 Quote Link to post Share on other sites
bennyk 1,238 Posted September 3, 2016 Report Share Posted September 3, 2016 Got my bbs avantgardes back after having them done in a grey base coat, diamond cut then finished in satin laquer, not to impressed with the finish though, unfortunately the place I had them done promised the earth but couldn't deliver ? daveyboy, VR6 Supercharged, VR6Pete and 1 other 4 Quote Link to post Share on other sites
VR6Pete 1,452 Posted September 4, 2016 Report Share Posted September 4, 2016 Got my bbs avantgardes back after having them done in a grey base coat, diamond cut then finished in satin laquer, not to impressed with the finish though, unfortunately the place I had them done promised the earth but couldn't deliver ? Look goood from a distance. What's wrong with the finish mate? Quote Link to post Share on other sites
bennyk 1,238 Posted September 5, 2016 Report Share Posted September 5, 2016 Look goood from a distance. What's wrong with the finish mate?They've got a circle Mark around the middle under the clear coat, there's a load of shit in the clear and the edges of the painted bits are a bit flakey, basically a bit of everything, if only I could diamond cut them myself! I think the sayings if you want something doing properly do it yourself! daveyboy, VR6Pete and VR6CABBS 3 Quote Link to post Share on other sites
InariVR6 1 Posted September 8, 2016 Report Share Posted September 8, 2016 I stuck an original gear knob on traffic. Feels much better than the old wolfsberg one. VR6Pete 1 Quote Link to post Share on other sites
Gleasoz 2 Posted September 8, 2016 Report Share Posted September 8, 2016 Ordered a SS crackpipe. And an removing my SAI pump. VR6 Supercharged and VR6Pete 2 Quote Link to post Share on other sites
VR6Pete 1,452 Posted September 26, 2016 Report Share Posted September 26, 2016 I love my Corrado too much. VR6 Supercharged, boab3 and six appeal 3 Quote Link to post Share on other sites
boab3 164 Posted September 27, 2016 Report Share Posted September 27, 2016 Test fitted charger before fitting new bearings etc Tank_VR, VR6Pete, six appeal and 1 other 4 Quote Link to post Share on other sites
VR6Pete 1,452 Posted January 18, 2017 Report Share Posted January 18, 2017 passed my corrado looking sad for itself recently ! Got a load of jobs to do on it but no time !! VR6 Supercharged 1 Quote Link to post Share on other sites
VR6Pete 1,452 Posted February 5, 2017 Report Share Posted February 5, 2017 Went to move the car last weekend and had flat battery. pulled the bonnet release handle and nothing happened was preparing for the worst this weekend but luckily was able release without taking a grinder to it by pushing down and pulling up the bonnet when handle was pulled. I just gave the mechanisms a good spray of wd40 and greased up and normal service has resumed. Battery charged up and looking forward to drive to work tomorrow. VR6 Supercharged 1 Quote Link to post Share on other sites
VR6Pete 1,452 Posted February 6, 2017 Report Share Posted February 6, 2017 Drove it this morning, felt really good to drive Slight belt slip to begin with due to a lot of condensation build up everywhere from cold weather this morning - may get some anti-belt slip as don't really want to tighen up anymore as boosts perfectly after about 20 mins of driving. VR6 Supercharged and cactusjackslade 2 Quote Link to post Share on other sites
VR6 Supercharged 104 Posted February 6, 2017 Report Share Posted February 6, 2017 1 hour ago, VR6Pete said: Drove it this morning, felt really good to drive Slight belt slip to begin with due to a lot of condensation build up everywhere from cold weather this morning - may get some anti-belt slip as don't really want to tighen up anymore as boosts perfectly after about 20 mins of driving. Not done anything with my VR today or for weeks now as its still at the tuning firm have the map tweaked an then some Vibratechnic engine mounts fitted. Went out in the wifes yesterday though for a couple of hours which was fun... cactusjackslade 1 Quote Link to post Share on other sites
The Monk 50 Posted February 9, 2017 Report Share Posted February 9, 2017 Pulled coil packs on 3 and 4 yesterday. Sucked over 20 ml of oil from each slot. Desperately need to replace the rocker gaskets but I really can't be bothered to remove the front end, tensioner and alternator to do such a simple change. Stupid design flaw with the 24v, made even more annoying with the MPV 24v engine components costing almost twice as much as the SAME engine (cams excluded), as the gaskets for the Golf 24v versions. VR6Pete 1 Quote Link to post Share on other sites
Mk3highline 287 Posted March 1, 2017 Report Share Posted March 1, 2017 Got a new ecu on its way, as old one was tried on another vr6 and wasn't able to start it either VR6 Supercharged and VR6Pete 2 Quote Link to post Share on other sites
VR6 Supercharged 104 Posted March 1, 2017 Report Share Posted March 1, 2017 3 hours ago, Mk3highline said: Got a new ecu on its way, as old one was tried on another vr6 and wasn't able to start it either Well again still not done a thing with my VR as its still not back... That said though I did spend 10 min's in my local van breakers yesterday with a lump hammer and uber sharp wood chisel cutting out the wing vent from a Merc Sprinter ready to graft into the front wing of my VR when it finally comes back. Got a strange look from the owner mind when I said "Have you got any knackered wings in (for said van) not bothered if rotten, dented etc so long as the vent's a good un?) Him said "What years your van"? I said "Its a MK3 Golf" the look on his face was priceless as he didn't know what to say... . VR6CABBS and VR6Pete 2 Quote Link to post Share on other sites
VR6 Supercharged 104 Posted March 3, 2017 Report Share Posted March 3, 2017 Well finally got my VR back today a very happy man.... Tank_VR, Brannonc4, VR6CABBS and 2 others 5 Quote Link to post Share on other sites
