Hi all,
I have recently completed a MK2 VR6 conversion using the wide track, brakes etc from the MK3 golf. I also converted the MK2 to ABS using the MK3 equipment. Since installing it it has not worked correctly, the brakes are awesome but the abs is not kicking in.
When i bought the Donor car the ABS light was on so i knew it had a problem, which i thought i would tackle once complete. i have checked all the voltages etc on the ABS brain and they are all fine. I did find that there where no ABS pick up rings on the rear brakes, which i thought was causing the problem. I have now installed new rings and cleaned all the sensors. The ABS is still not kicking in. I have not run it down the road yet and have just been checking it in my yard and was wondering if a 5 - 10 mile run down the road might clear the problem, just trying to sort it out myself without having to pay to have it vagcom'd? Oh by the way i don't have the ABS light connected.
Any help would be great.
