replacing rear engine mount...
i set about trying to replace the rear engine mount on the vento vr 1997 and its a bit of a mission unless i am doing something wrong
so i have a few questions
1.is the rhs engine mount the RHS looking into engine or RHS from Driver seat? when i attempted the rhs from the engine view it looksed different
2.how to you get the mount out? i raised the engine as much as i could and it would not come out , do i need to release the front engine mount?
this is the one i am trying to replace
http://webhosting.web.com/imagelib/sitebuilder/misc/show_image.html?linkedwidth=actual&linkpath=http://www.epmtuned.com/sitebuildercontent/sitebuilderpictures/VAG885M880MX.jpg&target=tlx_pichbws
Thats the rear engine mount, as your lookin at the front its on the left in front of where you sit lol. IIRC from the top you undo the nut take the heatshield off the remove the bolt, its a weird bolt with thread exposed for aforementioned shield) then jack the engine up you should then be able to undo the two bolts holding the mount to the subframe? Hope this helps
