cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 got mine from demon tweeks http://www.demon-tweeks.co.uk/ and 42 draft http://store.42draftdesigns.com/index.html( bit expensive thou ) Link to post Share on other sites
Ben Seabrook 4 Posted April 19, 2009 Report Share Posted April 19, 2009 I like this one http://www.swgmotorsport.com/asps/ShowDetails.asp?id=217 - again bit pricy though Link to post Share on other sites
Ben Seabrook 4 Posted April 19, 2009 Report Share Posted April 19, 2009 plenty of choice here http://stores.shop.ebay.co.uk/GlowShift-International-Store__W0QQ_armrsZ1 Link to post Share on other sites
craggsy 91 Posted April 19, 2009 Author Report Share Posted April 19, 2009 So along with a boost gauge what other is needed? Oil pressure? A/F meter?Come on guys this like getting blood from a stone!!! Link to post Share on other sites
cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 lol i would defo go for oil pressure can tell alot from oil pressure you dont need oil temp cos you got the dash for that ... so AF and maybe a voltmeter not really much more you need Link to post Share on other sites
craggsy 91 Posted April 19, 2009 Author Report Share Posted April 19, 2009 Cool........I knew I could prize the answers out of ya eventually....lol Link to post Share on other sites
Ben Seabrook 4 Posted April 19, 2009 Report Share Posted April 19, 2009 what Tony said Link to post Share on other sites
cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 lol juat trying to see how long i could keep you asking for .... so whens it goin in then??? Link to post Share on other sites
UnitedMotorsport 55 Posted April 19, 2009 Report Share Posted April 19, 2009 When you run forced induction a WIDEBAND A/F gauge is a must. They give you a very good idea of what is gping on and how well your engine is running. Link to post Share on other sites
cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 so where you thinking of puttin the gauges then ?? Link to post Share on other sites
craggsy 91 Posted April 19, 2009 Author Report Share Posted April 19, 2009 I like the look of these but boost one only comes in Bar.....might get annoying I think tho not a massive problemhttp://cgi.ebay.co.uk/ANY-2-SMOKED-GAUGE-53-99-BOOST-OIL-PRESSURE-WATER-TEMP_W0QQitemZ350191916027QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item350191916027&_trksid=p3286.c0.m14&_trkparms=72%3A1689|66%3A2|65%3A12|39%3A1|240%3A1318 Link to post Share on other sites
cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 yeah look pretty cool stayes with the black on black look .... yeah i did have a Bar but then went to psi so much better as im only running 12 psi Link to post Share on other sites
Ben Seabrook 4 Posted April 19, 2009 Report Share Posted April 19, 2009 they do look nice mate - when I get the car back on Tuesday will check what make mine is, as it shows boost in psi and fits nicely into the vent to the right of the steering wheel - easy mod Link to post Share on other sites
craggsy 91 Posted April 19, 2009 Author Report Share Posted April 19, 2009 When you run forced induction a WIDEBAND A/F gauge is a must. They give you a very good idea of what is gping on and how well your engine is running.The way i'm reading about wideband is that something needs to be welded somewhere to place the sensor. Welding is beyond my talents!!!so where you thinking of puttin the gauges then ??Well i'm thinking where stereo sits as its easier to see em, stereo down below me thinks Link to post Share on other sites
cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 When you run forced induction a WIDEBAND A/F gauge is a must. They give you a very good idea of what is gping on and how well your engine is running.The way i'm reading about wideband is that something needs to be welded somewhere to place the sensor. Welding is beyond my talents!!!so where you thinking of puttin the gauges then ??Well i'm thinking where stereo sits as its easier to see em' date=' stereo down below me thinks[/quote']yeah i done that but didnt like it but jims got them there ... mine are now in the cubby hole and radio back in normal place as for the wideband think you can use the wiring from you o2 sensor ???? as thats wot it reads it off .... mayeb be wrong but thats wot ive read Link to post Share on other sites
craggsy 91 Posted April 19, 2009 Author Report Share Posted April 19, 2009 Reading on t'interweb it says standard lambda is narrowband so only tells you if you are running lean or rich. Not a precise reading, might just go with running from lambda for now Link to post Share on other sites
UnitedMotorsport 55 Posted April 19, 2009 Report Share Posted April 19, 2009 When you run forced induction a WIDEBAND A/F gauge is a must. They give you a very good idea of what is gping on and how well your engine is running.The way i'm reading about wideband is that something needs to be welded somewhere to place the sensor. Welding is beyond my talents!!!Using a wideband gauge involves having an extra lambda sensor place welded into your exhaust. Then a wideband sensor is screwed into there. A wideband gauge does not wire into the existing narrow band sensor.When gauges are wired into the existing narrowband sensor, this 99% of the time causes running problems.Welding maybe betond your skillset, but when running FI it is well worth it, You will soon see when something is wrong, or when your engine is about to melt. If you cant weld your self then maybe someone would weld one in for you. Link to post Share on other sites
cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 could always fitt wideband when you fitt a de-cat get an extra plug welded in and jobs a fish Link to post Share on other sites
UnitedMotorsport 55 Posted April 19, 2009 Report Share Posted April 19, 2009 could always fitt wideband when you fitt a de-cat get an extra plug welded in and jobs a fish Thats a good idea! Link to post Share on other sites
cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 been looking a wideband my self so this has helped me out alot just need to save now lol as they say everyday is a school day Link to post Share on other sites
craggsy 91 Posted April 19, 2009 Author Report Share Posted April 19, 2009 Good thinking there Tony..............not just got jellied eels between the ears then...lolSo what sorta prices are wideband kits then? Link to post Share on other sites
craggsy 91 Posted April 19, 2009 Author Report Share Posted April 19, 2009 Might have to sell Schrick to pay for some of this....we'll see! Link to post Share on other sites
cabrioman 6 Posted April 19, 2009 Report Share Posted April 19, 2009 aint found them for under £150 yet but still looking Link to post Share on other sites
craggsy 91 Posted April 19, 2009 Author Report Share Posted April 19, 2009 Im just waiting for Kev haywire to come along and tell me where from and what to get Link to post Share on other sites
Ben Seabrook 4 Posted April 19, 2009 Report Share Posted April 19, 2009 about £200 on ebay matey - good to know about this and the de-cat and could put one into mine before it goes onto the car Link to post Share on other sites
