sparkz 0 Posted April 13, 2009 Report Share Posted April 13, 2009 Looking at converting my mk2 to 4wd and have been offered a setup from a v6 4mo for pennies... Now apart from the obvious (floorpan, etc) will the rest bolt up easily enough? Has anyone done it? I know the mk3 syncro and rallye setup bolts up, but not too sure if anyone has done the mk4 route on their mk2...any help will be much appreciated! Link to post Share on other sites
UnitedMotorsport 55 Posted April 13, 2009 Report Share Posted April 13, 2009 MK4 rear subframe/arms/hubs dont fit easily into the mk2.Best approach is to modify a MK2 4wd rear beam to accpet the rear diff from the MK4. Link to post Share on other sites
sparkz 0 Posted April 13, 2009 Author Report Share Posted April 13, 2009 MK4 rear subframe/arms/hubs dont fit easily into the mk2.Best approach is to modify a MK2 4wd rear beam to accpet the rear diff from the MK4.Cheers matt for the quick reply...what if i was able to get hold of a 1.8 syncro mk2 rear beam...would that be ok to use? Link to post Share on other sites
Phat VR6 3 Posted April 14, 2009 Report Share Posted April 14, 2009 http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=48002&start=0 Link to post Share on other sites
sparkz 0 Posted April 14, 2009 Author Report Share Posted April 14, 2009 Cheers for that link mate! Link to post Share on other sites
pops 1 Posted April 14, 2009 Report Share Posted April 14, 2009 looks like its possible but with 1/2ton of metal added, most of it welding wire , i`d go with the tried and tested mk2 rear frame converted to haldex Link to post Share on other sites
Eat this 2 Posted April 14, 2009 Report Share Posted April 14, 2009 storm have a haldex mk2 r36 running dont they? give em a call Link to post Share on other sites
Phat VR6 3 Posted April 17, 2009 Report Share Posted April 17, 2009 looks like its possible but with 1/2ton of metal added' date=' most of it welding wire , i`d go with the tried and tested mk2 rear frame converted to haldex [/quote']LOL he is a nutter... personal i think its great. especially his welded drive shafts :S Link to post Share on other sites
Lizard Racing 0 Posted April 18, 2009 Report Share Posted April 18, 2009 storm have a haldex mk2 r36 running dont they? give em a callNo John its a Syncro, no need for Haldex as its still only N/A, amazing car though! Link to post Share on other sites
Eat this 2 Posted April 18, 2009 Report Share Posted April 18, 2009 storm have a haldex mk2 r36 running dont they? give em a callNo John its a Syncro' date=' no need for Haldex as its still only N/A, amazing car though![/quote']ah ok whats the mental charged 3.6 in then?ps you got that answer for me yet mate Link to post Share on other sites
VR6BOY 2 Posted April 21, 2009 Report Share Posted April 21, 2009 Here is a cheap enough kit Patrick http://www.dutchbuild.com/product_info.php?cPath=17_50&products_id=29When fitting an 02M gearbox into a mk2/3 shell you need an 02M gearbox mount and modify an 02A front engine mount DB used to sell them already modified making it an easier way to convert over, The subframe needs to be modded by moving the gearbox flange forward by roughly 10/12mm (to clear the subframe mounts) Link to post Share on other sites
sparkz 0 Posted April 21, 2009 Author Report Share Posted April 21, 2009 Aaron!! Ive been wanting to speak to you, butdidnt want to ask vince for your number, can you pm me your number please? Link to post Share on other sites
VR6BOY 2 Posted April 22, 2009 Report Share Posted April 22, 2009 PM sent Patrick but having internet troubles here at the moment so dont worry if you get 5/6 pm's LOL Link to post Share on other sites
Phat VR6 3 Posted April 22, 2009 Report Share Posted April 22, 2009 C2s gearbox mount doesn't need the sub frame cup chopping and re welding. perhaps an easyer option?http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?280459.10#post_282535 you might have seen it already but 4 wheel drive in a mk3 Link to post Share on other sites
