kie_dub 0 Posted March 17, 2009 Author Report Share Posted March 17, 2009 thanks jim ill have a look when i get in. If its the head gasket then wouldnt the car be overheating? Link to post Share on other sites
jims13 6 Posted March 17, 2009 Report Share Posted March 17, 2009 no, not if its only weeping or burning it off. both are possbile.. do you use alot of water that cant be accounted for ? Link to post Share on other sites
kie_dub 0 Posted March 18, 2009 Author Report Share Posted March 18, 2009 i did do but just had the radiator changed so need to wait a while about this to see if the water drops over the next week or so, so whats the chances of it blowing up lol? Link to post Share on other sites
Bobtrude 0 Posted March 18, 2009 Report Share Posted March 18, 2009 If u have a gasket leak I dont think it will blow up if u drive off boost. If its the coil it wont boost much . . . .Just try to diagnost it and take it from there. Link to post Share on other sites
jims13 6 Posted March 18, 2009 Report Share Posted March 18, 2009 more likely to blow up , if you dont have enough fuel Link to post Share on other sites
kie_dub 0 Posted March 18, 2009 Author Report Share Posted March 18, 2009 cheers jim! lol, now i am poo-ing it just going to take my time until i get it sorted. Ive found oil slowly seeping from a joint in the engine il try and get a pic up 2night of it. I think its between the block and bottom end but i aint a mecanic and not sure if thats the right sections Link to post Share on other sites
MaidenVR6 26 Posted March 18, 2009 Report Share Posted March 18, 2009 You need to to this:Get your AFR measured. That is priority nr1 !A tuning company should have this.Or buy one: http://store.summitracing.com/partdetail.asp?autofilter=1∂=AVM%2D30%2D4100&N=700+115&autoview=skuThen you see how rich or lean it runs.Then use VAG COM to see if you have any bad sensors. Delete all faults and check again.Then, you need to check your intercooling piping. Pressure test it. 25 psiI had a intercooler leak last summer, and the car ran like shit some times. I couldt find the problem, but after a pressure test we found it. I had a bad cam sensor as well. Car didnt have the power It used to.But with all this fixed, it was running perfect again.Good luck. Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 cheers maiden,right i have took some pictures of were i have seen oil seeping from i will upload them shortly. just put my foot down on the way home and couldnt see any smoke as i didnt have anyone to look yet. when i stopped at the lights, it idles crap, where its ment to be at 800rpm on tick over it goes 800-600-800-600 etc then every so often drops down to 400 and picks back up before it cuts out Link to post Share on other sites
Phat VR6 3 Posted March 19, 2009 Report Share Posted March 19, 2009 sounds like a air leak somewhere after the MAF to me mate.Had it a few time on N/A motors causing them to huntCould also be MAF senser tbf i can imagine owning a VRT and not been a mechanic or self taught been a complete nightmare This is the way you will learn anywayhave you checked the compressor outlet for oil yet? Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 this is the side of the engine that has a slight oil leak, if you look just about the air filter you will see it Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 ignore all the salt i havent got round to cleaning the engine yet Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 sounds like a air leak somewhere after the MAF to me mate.Had it a few time on N/A motors causing them to huntCould also be MAF senser tbf i can imagine owning a VRT and not been a mechanic or self taught been a complete nightmare This is the way you will learn anywayhave you checked the compressor outlet for oil yet?yes bodge it is a nightmare and very expensive because i have to pay other people to do things! i need some lessons lol!the compressor outlet for oil?? :si have just put a pic up of where i have seen oil leaking fromgoing to clean the air filter asap aswel as it needs a clean, any ideas of whats best to clean them with? i dont know anybody local who has vagcom and dont fancy paying hundreds for it as i dont have the spare cash at the mo due to holidays. What do you lot think it could be then with the info i have put so far? still not done everything Link to post Share on other sites
Phat VR6 3 Posted March 19, 2009 Report Share Posted March 19, 2009 sounds like a air leak somewhere after the MAF to me mate.Had it a few time on N/A motors causing them to huntCould also be MAF senser tbf i can imagine owning a VRT and not been a mechanic or self taught been a complete nightmare This is the way you will learn anywayhave you checked the compressor outlet for oil yet?yes bodge it is a nightmare and very expensive because i have to pay other people to do things! i need some lessons lol!the compressor outlet for oil?? :si have just put a pic up of where i have seen oil leaking fromgoing to clean the air filter asap aswel as it needs a clean' date=' any ideas of whats best to clean them with? i dont know anybody local who has vagcom and dont fancy paying hundreds for it as i dont have the spare cash at the mo due to holidays. What do you lot think it could be then with the info i have put so far? still not done everything [/quote']No one can say for sure dude sorry. your head gasket does seem to be leaking a bit (common place) but isn't nesseraly a big problem.Most garages will vag.com for £30-40or you can get it off ebay for about £20 if you got a laptop You could have more than one problemdon't think anyone will be able to say change this and it will be fixed. needs looking at Link to post Share on other sites
Dave Lea 4 Posted March 19, 2009 Report Share Posted March 19, 2009 i aint 2 far from u if u dont mind a trip to my garage i will plug it in 4ya fella Link to post Share on other sites
jims13 6 Posted March 19, 2009 Report Share Posted March 19, 2009 noticed your on standard head bolts, not arp studs.. be surprised if it holds long at 400 + bhp.may be a weeping headgasket Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 are the arp bolts easy to fit jim? like is it basically old out new in, 10 min job or is it strip the engine? Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 i aint 2 far from u if u dont mind a trip to my garage i will plug it in 4ya fellagood times! where is your garage? how much would it cost to vag com and have comp test or how much just for vag com? Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 sounds like a air leak somewhere after the MAF to me mate.Had it a few time on N/A motors causing them to huntCould also be MAF senser tbf i can imagine owning a VRT and not been a mechanic or self taught been a complete nightmare This is the way you will learn anywayhave you checked the compressor outlet for oil yet?yes bodge it is a nightmare and very expensive because i have to pay other people to do things! i need some lessons lol!the compressor outlet for oil?? :si have just put a pic up of where i have seen oil leaking fromgoing to clean the air filter asap aswel as it needs a clean' date=' any ideas of whats best to clean them with? i dont know anybody local who has vagcom and dont fancy paying hundreds for it as i dont have the spare cash at the mo due to holidays. What do you lot think it could be then with the info i have put so far? still not done everything [/quote']No one can say for sure dude sorry. your head gasket does seem to be leaking a bit (common place) but isn't nesseraly a big problem.Most garages will vag.com for £30-40or you can get it off ebay for about £20 if you got a laptop You could have more than one problemdon't think anyone will be able to say change this and it will be fixed. needs looking at 20 quid off ebay? i thought it was hundreds. yeh i av got a laptop Link to post Share on other sites
Ben Seabrook 4 Posted March 19, 2009 Report Share Posted March 19, 2009 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=280311346654 one of these mate and you need to download the software which is free - but check your laptop does not have vista on it - otherwise it's a total pain Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 yup its got vista, its a new laptop about 2 month old, bummer! nothing is straight forward for me Link to post Share on other sites
Ben Seabrook 4 Posted March 19, 2009 Report Share Posted March 19, 2009 ah well that is a lsight problem then mate !! i have ended up getting an old second hand laptop just to run vagcom on - would take Dave up on his offer and bring it down to Spring fest gently and we can do it for you then Link to post Share on other sites
kie_dub 0 Posted March 19, 2009 Author Report Share Posted March 19, 2009 yeh i think that that is the best way innit, dave being dlea? and i bet you guys know alot about fi vr6's aswell so might be able to get down to the bottom of it. btw i was just wondering, my wastegaste/bleed valve is set to about 12 psi at the min i used to run it at 15-17 but turned it down abit, If i floor it in say 2nd so i am getting mostly grip then come off the revs abit to let the traction catch up if you know what i mean could this make the car buck with the wastegate being half open half closed? Link to post Share on other sites
Bobtrude 0 Posted March 20, 2009 Report Share Posted March 20, 2009 Good tip: read some build threads. Like the sticky one on the tuning page. . . . You will learn ALOT about your engine and the difference between turbo and NA (natural aspirated;))Also read the buildthreads on Projects cars and rides.My 2cents Link to post Share on other sites
kie_dub 0 Posted March 20, 2009 Author Report Share Posted March 20, 2009 anybody know what it could be yet? looking back at the info i have provided so far? Link to post Share on other sites
