project rebuild and 300 plus bhp... up dated 02/08/09... last chapter ....
As its the winter and my tax has now run out i decided to take my baby off the road and give her some much needed tlc .... well she has had a hard few months to say the least lol ...
And to get a bit more power and get into the low 13s next year ...
The list :-
1. Rebuild the engine with 2.9 bottom end (y) , head spacer (y) , 12 psi pullie (y) , 263 cams, and arp head bolts (y) , fix boost leaks (y) , sort out wiring loom (y) .... hopefully see about 300-320 bhp !!
2. Stripp and rebuild gear box with LSD. (y)
3. Replace rear axle bushes with poly (y) , fitt uprated anti roll bar (yn) , fitt rear strut barce. (yn)
4. Replace front wishbone bushes (y) anti roll bar bushes and drop links with poly ones (y) , uprate front aint roll bar (yn) ,
5. Recon steering rack as top seal leaking (y) ,
6. Replace all brake lines (y) , fitt audi tt 312 mm front brakes (y) replace rear discs and pads. (y)
7. Relocate gauges and radio (y) , remove boot build (save weight) (y) sort out heated seats.
8. Remove letter box (axle box) slincer from exhaust.
9. Maybe some new rims or replace the two buggered ones and powerd coat them white ... gota work out best size for track and drag racing... (y)
10. Sort out body work.
few got quite a bit to be gettin on with ... watch out for pics and progress reports and a few how to`s ...
  • Replies 279
  • 4 weeks later...
  • 4 weeks later...
done some more palying over the past few weeks
fitted front subframe, wishbone`s with new bushes, steering rack, ARB bushes,
replaced steering uj gator as had big hole ...
and gave the brakes a lick of paint ....
now for the fun bit engine and gearbox which i will bw staring in the new year
  • 3 weeks later...
just spent the last few days strippin the engine and found this !!!
sump quite dented and oil pump pushed up a bit lol .... bugger
white circle big dent and red one there oil pump was sitting lol
wots left of the oil scraper rings on numbers 1 and 3 pistons ... that be the smoke problem found then !!
also got some new stuff
some very sexy and very light pullies ... mmmm cheers clarkie
some new ARP head studs and main studs .... once again cheers clarkie lol
and a rear brace thanks santa
