chris red vr6 0 Posted August 6, 2008 Report Share Posted August 6, 2008 Hi quickly doing my 2nd post lolThis was another fault code that came up and after inspection found it in pieces so definately need a new one.I have a dizzy and seen that people have changed the hall sender by taking of the dizzy.Is it possible to change it without removing the dizzy and if not how easy is the dizzy to get of?I've done a search and going to try and get one from the place that gav recommended a while ago. Link to post Share on other sites
gav_113 0 Posted August 8, 2008 Report Share Posted August 8, 2008 u have 2 remove dizzy..remove cap and leads.. 2 ten mm bolts and pull off.. hall sensor is in the bottom of dizzy.. Link to post Share on other sites
chris red vr6 0 Posted August 9, 2008 Author Report Share Posted August 9, 2008 Thanks Gav looks like i should be able to get the sensor from the place you said even though its not listed on there website.Mind you on there first attempt although i asked for the hall sender i got an ignition coil sent out??Spoke to another guy since and seems alot more clued up so should be ok now.Never removed a distributor before and was worried about messing the timing up hence why i asked. Link to post Share on other sites
