  • Replies 272
Popular Posts
Well stuck it together tonight, just to make sure it all fits together still happy with result so thought I'd share.
Install time Still a fair bit to do but getting there
  • 3 weeks later...
Well bit of an update, been moding bay quite a bit over past couple of weeks but finally got in in high build primer today, chuffed to bits with it tbh..
To start with, though this would look good
Then replicated in sheet metal
Raised the turrets 25mm
weld, fill, sand,fill,sand
and finnaly how it stands today
Really liking the smoothing out and you certainly don't muck about do you? How did it do at the shows last year?
Thanks mate, loads still to do though, interior and finish rebuilding the motor
Last year won Player UD car of show, runner up car of show @ Dubshed and third place mk3 at E38, was really happy with that as I wasn't happy with the car but didn't want to miss them.
Test fit with jack under wheel, reckon another 10mm with engine weight to compress bags more B)
Swapped botom arms side to side and flipped the arb drop link so no mods required to them as subframe bolt access hole is larger and recessed on underside, 10mm clearance at this height
Productive day today although camera flat and forgot charger...
Flatened and polished the full engine bay.
Finished all the wiring ready for the dash to go back in.
Fitted and plumbed up the pedal box, just need to sort a throttle cable out and thats finished too.
Hopefully get engine back early in the week and have that back in by the weekend
