macvwnut 0 Posted July 16, 2008 Report Share Posted July 16, 2008 HiI have been involved in the VW Scence for years but i have just bought my first VR6 so any help and advice would be much appreciated.My car MK3 VR6 5 door year 1995Problems:1. The central locking does not work correctly could this be the pump?, also the petrol cap is locked into place could this be linked to the central locking?2. The coolant light is constantly flashing, fans do not appear to be working checked fuse seems ok ? problem with Fan.3. The rear passenger electric window does not close smoothly had to force it shut, will open ok.Any help would me much appreciated.Cheers Simon Link to post Share on other sites
jezmoz 0 Posted July 16, 2008 Report Share Posted July 16, 2008 1. most probably pump2. are you losing coolant? white smoke etc? dodgy sensor, VAG COM needed?3. window motor and or regulator need replacing. Link to post Share on other sites
mike 6 Posted July 16, 2008 Report Share Posted July 16, 2008 could be the pump, if its in all doors its highly likely, i have a central locking pump for sale btwcoolant light only usually comes on if low on coolant? could be a sensor...on the window, you could buy a new motor, or could need adjusting? Link to post Share on other sites
macvwnut 0 Posted July 16, 2008 Author Report Share Posted July 16, 2008 could be the pump' date=' if its in all doors its highly likely, i have a central locking pump for sale btwcoolant light only usually comes on if low on coolant? could be a sensor...on the window, you could buy a new motor, or could need adjusting?[/quote']Thank you for the advice, how much do you want for the pump? Link to post Share on other sites
