akz786 0 Posted July 15, 2008 Report Share Posted July 15, 2008 its a 1997 VR6 OBD2 ....all is well really ....just a werid noise maybe electric pump? basically when driving if I accelerate then let foot off gas to change gear i hear a whining which start loud then goes soft very quick (not mechanical) kind of sound which seems like its comming from top of engine. Could this be the aux pump running or a breather pipe blocked? Any suggestion appreciated.Thanks Link to post Share on other sites
rigs 0 Posted July 15, 2008 Report Share Posted July 15, 2008 Do you mean the sounds happens when you let off the power and roll in gear or when you put your foot on the clutch to change gear and the engine speed slows? Link to post Share on other sites
akz786 0 Posted July 15, 2008 Author Report Share Posted July 15, 2008 Hi no sorry its not dependant on the gear change or clutch as such...even if i am parked in neutral and rev the caras it revs down you hear this whine, or pump like sound although it does not hinder the cars performance in anyway....i initially thought it might be the aux pump running or a breather hose blocked just wanted to know if anyone has experienced this kind of sound. Link to post Share on other sites
rodney 17 Posted July 15, 2008 Report Share Posted July 15, 2008 two things dont let off the accelerator and second is it a belt kinda whine like on a charger or the likes? and not an electrical whine like on the stereo???? Link to post Share on other sites
xyber 1 Posted July 15, 2008 Report Share Posted July 15, 2008 mine does it, my mates does it, it stops when the engine has warmed up, was a thread about this before and loads of people get the same sort of a quiet straight cut gears sound Link to post Share on other sites
akz786 0 Posted July 15, 2008 Author Report Share Posted July 15, 2008 RCF - No its not a belt whine more like a pump whine but only noticable from cold once warmer it gets quiter ...Xyber - so what exactly is this noise? I tried to a search on here could not find anything....is it anything to worry about? Link to post Share on other sites
sticks 0 Posted July 17, 2008 Report Share Posted July 17, 2008 hi i also get this when de-pressing the gas pedal,but once fully warmed it goes,sounds like a off tune saxaphone,its a mystery no one still cannot seem to know what it is,good luck Link to post Share on other sites
akz786 0 Posted July 17, 2008 Author Report Share Posted July 17, 2008 hi i also get this when de-pressing the gas pedal' date='but once fully warmed it goes,sounds like a off tune saxaphone,its a mystery no one still cannot seem to know what it is,good luck[/quote']Thats exactly the sound im on about "like a off tune saxaphone" lol ....well if anyone knows what this is ...would be good to find out, I cant seem to find any info on it here?thanks Link to post Share on other sites
xyber 1 Posted July 17, 2008 Report Share Posted July 17, 2008 RCF - No its not a belt whine more like a pump whine but only noticable from cold once warmer it gets quiter ...Xyber - so what exactly is this noise? I tried to a search on here could not find anything....is it anything to worry about?I have a feeling its something to do with the throttle body if I recall whilst the engine is cold, nothing to worry about anyway, ill try and find the post Link to post Share on other sites
tonk 0 Posted July 17, 2008 Report Share Posted July 17, 2008 does everyone that 'hears' strange noises have climatronic fitted? Link to post Share on other sites
xyber 1 Posted July 17, 2008 Report Share Posted July 17, 2008 It was nagging so did some hunting, (copied and pasted)Secondary air injectionThe ECU electrically pulls a small solenoid valveopen, allowing manifold vacuum to go to a bigger valve(the combi-valve), which opens a passage from anelectrical air pump to a passage in the head that goesto the exhaust passages. The ECU also turns the airpump on and it blows fresh air into the exhaust. Thisis in the first 2 minutes or so after a true coldstart. It helps finish burning the rich defaultexhaust mixture that is used before the O2 sensorheats up and the system can go to closed loopmetering. The process of the burn completion alsoheats the catalyst faster, resulting in light-off in ashorter time.Both valves and the pump are under the intake manifoldbehind the radiator. Manifold vacuum comes off a "T"in the line to the fuel pressure regulator (silverdisc on the fuel rail).When the car is started and the coolant temperature isbelow a certain temperature (80C, I think), the ECUtests the system by turning it on for a couple ofseconds. This also happens right after the O2 sensorcomes on line after a cold start. Since the O2 isonline, the ECU expects to see at least a 25% leaner(more oxygen) signal from the O2 (less voltage) whilethe pump is running, because it's injecting fresh airinto the exhaust.Possibilities, in order of likelihood:1. 50a fuse has corroded and is not longer carryingcurrent. Check relay/fuse block with relay 111.Check your air pump gets 12v when the car's cold.2. Solenoid valve or combi-valve has failed. Air pumpgets 12v and runs but cannot dump air into exhaustthrough closed valve. If you can hear your air pumprun this might be the case.3. Air pump relay has failed.4. Air pump has failed. From what I hear it makesnasty bearing noises before it does though. Link to post Share on other sites
akz786 0 Posted July 17, 2008 Author Report Share Posted July 17, 2008 Now thats a good find! so not being stupid but if I am hearing the noise does that mean the air pump is working or the solenoid is stuck asd per point 2? . "Solenoid valve or combi-valve has failed. Air pumpgets 12v and runs but cannot dump air into exhaustthrough closed valve. If you can hear your air pumprun this might be the case." Link to post Share on other sites
sticks 0 Posted July 19, 2008 Report Share Posted July 19, 2008 hi tonk yer mine has clima fitted,also cheers xyber for that info. Link to post Share on other sites
xyber 1 Posted July 19, 2008 Report Share Posted July 19, 2008 Now thats a good find! so not being stupid but if I am hearing the noise does that mean the air pump is working or the solenoid is stuck asd per point 2? . "Solenoid valve or combi-valve has failed. Air pumpgets 12v and runs but cannot dump air into exhaustthrough closed valve. If you can hear your air pumprun this might be the case."possibly, but a little air pump will make that noise, if the valve was stuck id expect more of a hiss Link to post Share on other sites
akz786 0 Posted July 23, 2008 Author Report Share Posted July 23, 2008 by the way where exactly is this secondary air pump located? I cant see it ...I hear more of the noise inside the car than outside when the bonnet is popped open. Link to post Share on other sites
