Coolant bleed nippple. OBD2. Help needed asap
ye take the top of the tank make sure the water is at the MAX level, then start your car and leave it running for a while, the water will go everywhere tho so just watch it when its nearly empty top it up again to the max mark and it will proably empty again do this till both the big pipes that come off your rad are hot then you will know its done.
hope that helps mate
