lateral acceleeration sensor
i reset it with a mates vagcom twice but it doesnt dissapear. Does anybody know how to recode it?
4 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
57-00 - Electric Circuit Failure
01044 - Control Module Incorrectly Coded
35-10 - - - Intermittent
27-10 - Implausible Signal - Intermittent
00538 - Reference Voltage
57-10 - Electric Circuit Failure - Intermittent
Here are the faults...
Cheers
ive got the same problem my esp light stays on and my ABS light is also on.
mine comes up with code that the abs in incorrectly coded but i had a guy at vw put it on the vag com and he said its that acceleration sensor causing the problem its a black box screwed to a thin bar/bracket i think under the steering colum.
i have the new sensor, it is quite easy to get to and quite expensive also... can i just directly replace it or do i need to code it!
Dont want to take out the old one and put in the new one and get the same problem again!!
if you take off your panel under the steering wheel, rest your head on the pedals and look up you'll see a small box wrapped in bronze looking metal, attached to the steering column. This is your g200 latt acc sensor. there is also a bigger sensor attached- this is your yaw sensor. However i am no expert and have only come across this through research into my own problem.
  • 13 years later...
