NetStable 0 Posted April 12, 2008 Report Share Posted April 12, 2008 Hi AllI have been doing some diagnostics on a problem i've had for about 2 years and never sussed, the car can take about 20-30 secs to start when cold and is a pain in the arse,I have tested the fuel pressure with a gauge today and noticed that the pressure drops over the course of an hour or so which makes me think it's some kind of non-return valve. The only problem being... I'm not sure where the valve is, is it part of the pump?Any help is greatly appreciated! Link to post Share on other sites
Devildub_06 0 Posted April 13, 2008 Report Share Posted April 13, 2008 There may well will be a problem with the non return valve (not sure where they are), but should not be a major problem in any case as when you turn the ignition key to the ign position, the fuel pump "primes" the fuel system for 3-4 seconds, and should show on your fuel gauge a decent fuel pressure immediately before the engine's cranked.How many miles has your VR done? And does this occur when the engine is warm? After short runs/long runs etc? Link to post Share on other sites
NetStable 0 Posted April 14, 2008 Author Report Share Posted April 14, 2008 Cheers for the quick reply, the car has done 144,000 and it only really occurs when the car starts from cold, I have changed the ECT sensor and fuel pressure regulator amongst a few other things. Its more an irritation than a big problem but i've just had to get a new starter motor because of the stress it has had on that! Ta Link to post Share on other sites
Devildub_06 0 Posted April 14, 2008 Report Share Posted April 14, 2008 Not really huge mileage I see, but i'd be tempted to have a compression check done. If it only happens from stone cold it may be a compression issue. Link to post Share on other sites
