paceo 22 Posted April 24, 2012 Report Share Posted April 24, 2012 as you now im looking for a 312mm brake conversion on my mk3 vr6, i know you can use the mk4 GTI 312mm front calipers, are V6 4-motion 312mm calipers the same?? check link below.http://www.ebay.co.uk/itm/VW-GOLF-98-03-NEARSIDE-FRONT-BRAKE-CALIPER-312mm-DISCS-/320893711529?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AVW&hash=item4ab6c174a9:-) thanks Link to post Share on other sites
CALICO 130 Posted April 25, 2012 Report Share Posted April 25, 2012 You have just started a thread for the same question???? Link to post Share on other sites
cornishvr6 52 Posted July 2, 2012 Report Share Posted July 2, 2012 Am i right in thinking i can use the existing TT caliper brake lines when upgrading or have i got to swap the to Hel or Goodrich to get them fitted correctly?Also is the washer option ok to use to space the caliper? I was looking at ECS adaptor kit but the postage costs more than the goods 8-) Link to post Share on other sites
craggsy 91 Posted July 2, 2012 Report Share Posted July 2, 2012 I used waqshers on mine and had no problems. I cant see why you cant use the TT line as its a banjo fitment, tho I had goodridge put on mine Link to post Share on other sites
cornishvr6 52 Posted July 2, 2012 Report Share Posted July 2, 2012 I used waqshers on mine and had no problems. I cant see why you cant use the TT line as its a banjo fitment' date=' tho I had goodridge put on mine[/quote']Thanks for the info, will get down to my local hardware store and hopefully get them on before the weekend, £55 for the goodridge lines from C&R Enterprises seems too good to pass on whilst its getting done. Link to post Share on other sites
CALICO 130 Posted July 3, 2012 Report Share Posted July 3, 2012 Im using washers and they have been fine. Link to post Share on other sites
cornishvr6 52 Posted July 3, 2012 Report Share Posted July 3, 2012 Im using washers and they have been fine.Thanks for the info mate, How many did you have to use each side out of interest? Link to post Share on other sites
craggsy 91 Posted July 3, 2012 Report Share Posted July 3, 2012 I used 6 either side Link to post Share on other sites
Vince12v 20 Posted April 17, 2013 Report Share Posted April 17, 2013 Can't someone clarify on the bolt size u need!!?? Is it 12mm standard or fine thread or 10 mm fine thread Link to post Share on other sites
NPCS 0 Posted December 3, 2013 Report Share Posted December 3, 2013 As I am looking to only use my VR6 as a track car , just how much better are the 312mm's than the 288mm's ?? Of course I would be looking at some track pads and probably some drilled and grooved discs instead of standard 225 TT discs but if the improvement is not huge then I may consider a BBK. Cheers Neil Link to post Share on other sites
wardycatt 7 Posted December 3, 2013 Report Share Posted December 3, 2013 @NPCS - Different people on here have reported various results. Some say it does next to nothing, others claim significantly improved stopping power. Personally I think there should be some noticeable improvement (otherwise I wouldn't be in the process of doing this upgrade myself), but I don't expect to go through the windscreen when I stamp on the brakes with 312mm disks. It's difficult to say precisely what the difference is unless you conduct a properly scientific experiment. For example, if you upgrade to the 312mm calipers, you may change your brake fluid in the process. If the existing fluid has been in there for a while (many years in some cases), simply changing the fluid will improve your breaking... which you then might erroneously attribute to your new calipers. Ditto the new pads that are likely to have been installed as part of the upgrade - they may be doing more for the braking improvement than the bigger disks. So it's hard to prove exactly what improvement is caused *only* by the 312mm upgrade without some sort of test. I think it also depends on exactly which 312mm upgrade you go for. There are a wide range of compatible parts, some of which a rumoured to have slightly different dimensions or specifications. So the 312mm calipers from a Mk4 Golf may have a piston which is 1mm smaller than the piston from a TT's 312mm caliper, for example - which translates to different stopping distances (this is a theoretical example, don't quote me on that). But you catch my drift - you'd need to compare like-for-like in order to put this argument to bed once and for all. P.S. I'd personally go with dimpled as opposed to drilled disks. Or stick with plain disks and splash out on top-of-the-range pads instead. Each to their own I suppose - track use is a bit more punishing than my daily commute. NPCS 1 Link to post Share on other sites
Lukey. 381 Posted December 3, 2013 Report Share Posted December 3, 2013 Before you do anything, braided hoses. Ickyketseddie and PeteVRT 2 Link to post Share on other sites
Ickyketseddie 89 Posted December 3, 2013 Report Share Posted December 3, 2013 Before you do anything, braided hoses.This ^^^Sent from my iPad using Tapatalk Link to post Share on other sites
NPCS 0 Posted December 5, 2013 Report Share Posted December 5, 2013 Thanks guys for the info , all very useful. I have had many track prepped cars before but my first time with a Golf. All my previous cars have had a BBK fitted so may go down this route , but of course the cost is much greater. Link to post Share on other sites
wardycatt 7 Posted December 5, 2013 Report Share Posted December 5, 2013 Whilst we're on the subject of braided hoses for 312mm upgrades, am I right in thinking that I need the banjo-type connector for my Mk3 Golf (1997 model, OBD2)? The corresponding Goodridge part number is: SVW0607-4P Link to post Share on other sites
Lukey. 381 Posted December 6, 2013 Report Share Posted December 6, 2013 For obd2 with 288s yea you need banjo fronts. Link to post Share on other sites
wardycatt 7 Posted December 9, 2013 Report Share Posted December 9, 2013 Cool, thanks. Link to post Share on other sites
CALICO 130 Posted December 9, 2013 Report Share Posted December 9, 2013 I used 6mm washers Link to post Share on other sites
PeteVRT 22 Posted January 11, 2014 Report Share Posted January 11, 2014 (edited) Only just seen this, I'm using my brothers old S3 brakes, presume they are the same as the TT? Also agree with the brake fluid change and braided hoses, all older cars everything is deteriorated and standard flexi hoses expand under pressure, worse when older. Part of the MOT test is to check the hoses under pressure but how many garages do you see check them properly on an MOT Edited January 11, 2014 by PeteVRT Link to post Share on other sites
Swivelonit 119 Posted January 11, 2014 Report Share Posted January 11, 2014 As I am looking to only use my VR6 as a track car , just how much better are the 312mm's than the 288mm's ?? Of course I would be looking at some track pads and probably some drilled and grooved discs instead of standard 225 TT discs but if the improvement is not huge then I may consider a BBK. Cheers Neil I have just took 312mm off my 4 motion as they were OK but not fantastic on track, I was running Ferodo DS2500 pads and standard discs. I now have Brembo 323mm from a Leon Cupra R and DS3000 pads, I have also opted for HEL performance braided hoses for front and rears. You can see HERE what I have bought but not yet fitted. BTW, we are going to Oulton Park on Feb 21st if you want to fetch your Golf to the track? MSV NPCS 1 Link to post Share on other sites
Jakeyb 23 Posted March 13, 2014 Report Share Posted March 13, 2014 Top guide mate I'll be tackling this soon cheers for the tips n pictures Sent from my iPhone using Tapatalk Link to post Share on other sites
Cooz93 66 Posted May 1, 2014 Report Share Posted May 1, 2014 So if I have an early VR with 280 brakes, do I need to upgrade the hub to a mk4? Or just need the callipers, carriers, spacers bolts new hoses etc? Thought I understood but the more I read the less I know haha Link to post Share on other sites
Lukey. 381 Posted May 1, 2014 Report Share Posted May 1, 2014 you just need the mk4 brakes setup, carriers, callipers, discs, hoses, spacers, no new hubs Cooz93 1 Link to post Share on other sites
Cooz93 66 Posted May 1, 2014 Report Share Posted May 1, 2014 Nice one, cheers! Link to post Share on other sites
