Water in footwell
if it's anything like a golf ...water can come in through the bonnet release cable, if the grommet has perished, also check the scuttle panel for blockages, otherwise it could be a leaking heater matrix? or a dodgy window seal, take the door card off and have a look if the mebrane is damaged>?
I have the same problem with mine but in the passenger foot well. I thought it was the rear washer pipe as there is a join just as the wires come through the body-but it wasn't. If you check the removable panels coming round the bottom of the windscreen, you might find that the felt grommits have perrished. I put some no more nails in the hole and it has reduced it! I'm sure its not VW approved!!
  • 3 years later...
I'm just buying a galaxy with the Vr6 engine and a mechanic friend told me to look out for wet carpets in the front. apparently it can be the pollen filter under the bonnet which if not fitted/seated quite right can cause leak. I know this is an old thread but maybe will be of help to some one.
G
  • 5 years later...
