tongy 0 Posted December 31, 2007 Report Share Posted December 31, 2007 Hi folks right I gotta change the driver side bottom arm on my golf. What I need to know is how do you get the bolt past the sump??Cheers peeps Link to post Share on other sites
richievr 1 Posted December 31, 2007 Report Share Posted December 31, 2007 probably,a bit of a guess, undo the rear engine mount and jack up the engine slightly so that it goes underneath.i haven't done the drivers side on mine, only the passengers side fortunately... Link to post Share on other sites
tongy 0 Posted December 31, 2007 Author Report Share Posted December 31, 2007 I will put up a how to when I do it looks like its gonna be fun(not)Oh well Happy new year lol Link to post Share on other sites
richievr 1 Posted December 31, 2007 Report Share Posted December 31, 2007 he he ... do it.happy new year to you too... Link to post Share on other sites
craggsy 91 Posted January 1, 2008 Report Share Posted January 1, 2008 How to guides are always welcome matey. Dont forget pics whilst you're doing it tho' Link to post Share on other sites
tongy 0 Posted January 5, 2008 Author Report Share Posted January 5, 2008 Right then here we go.As you can see the sump in the way of the bolt.Solution undo the 13mm bolt first to remove the bracket that holds the 2 conectors so as not to damage them. Then there is a 17mm bolt through the mount into the chassis.Like so not too bad to get to. Then jack the engine up(use a piece of wood so you dont damage sump) you then have acces to the whishbone bolt Then undo rear wishbone bolt, antiroll bar linkage, bottom ball joint (3 bolts). I also took off the hub nut to allow better access and the track rod end, put it all back together in reverse order and hey presto.Hope this helps Thanx to everyone for the advice Tongy Link to post Share on other sites
