binliner 0 Posted January 21, 2004 Report Share Posted January 21, 2004 Ive had a minor coolant leak for a while but it seems to be getting a bit worse so time to sort it out..... apparantly its leaking from the thermostat housing and a new one is needed.Im waiting for the garage to get back to me with a price but just wondered if it was something I could do myself... anyone know how hard it is to do? Link to post Share on other sites
binliner 0 Posted January 22, 2004 Author Report Share Posted January 22, 2004 update: they reckon around £70+vat fitted. The part costs £20... anyone changed this before? Link to post Share on other sites
jcorallo 0 Posted January 22, 2004 Report Share Posted January 22, 2004 yep.You'll need to replace the coolant lost - which is £15 from Halfords.I allways use a dab of that orange silicon sealant - £2Best put a new Thermostat and seal in there - £7.Note: You might not need a new housing - it could just be the seal behind it... £20 you say? New?Jules Link to post Share on other sites
binliner 0 Posted January 22, 2004 Author Report Share Posted January 22, 2004 yeah they said about £20 plus £40-£50 labour... didnt mention the other bits so they'll probably go on the bill as well! Link to post Share on other sites
zerocool 0 Posted January 22, 2004 Report Share Posted January 22, 2004 its only held on by 3 Allan bolts and two hoses attach to it.its probably only the seal thats gone,but if you can afford it I would change the lot,get new allan bolts for it too.it took me about 30 mins to change one,the only awkward bit is getting the coolant pipes off,as the clamps require a special tool really, to compress them,but it can be done with a good pair of pliers. Link to post Share on other sites
binliner 0 Posted January 23, 2004 Author Report Share Posted January 23, 2004 cheers guys... so you can get to it ok without having to remove anything major? Link to post Share on other sites
zerocool 0 Posted January 23, 2004 Report Share Posted January 23, 2004 yeah its easy enough,but then I am a technician. Link to post Share on other sites
topgunvr6 0 Posted January 25, 2004 Report Share Posted January 25, 2004 I got my nextdoor neighbour to do it. It took us 1hr to do it max. as long as you drain all the coolant and disconnect the pipes joining the housing then its easy to do. darren Link to post Share on other sites
