Now as the weather gets colder i dont expect to hear too much from the second fan.
However i have recently had the fan cutting in quite regularly when in traffic etc...it only comes on for about 5 seconds then goes off.
I was just wondering if this has anything to do with the thermostat.
N.B- The oil temp is about 80degrees.
Thanks.
The second fan is connected to the first 1 with a rubber band there is no motor on it and it runs with the first 1 and that does seem to be a bit bizarre it might be a faulty temp sender which is the 4 pin yellow one.for fans oh and personally i cant see it being a prob with thermostat.carl.
