Littlebear 0 Posted July 23, 2007 Report Share Posted July 23, 2007 What is the part that is circled in red? She is leaking coolant right there at the T. I was wondering if a leak there would make my car run poorly cause it sure is and thats the only think I can find wrong. It is spitting and sputtering real bad[img:width=650]http://i130.photobucket.com/albums/p273/littlebear22/1.jpg[/img[Mod edit resize pic]Moderator edit by: cadguy Link to post Share on other sites
cadguy77 0 Posted July 24, 2007 Report Share Posted July 24, 2007 It's either the return or feed line to the heater matrix, the small bore line feeds the u-loop in the TB. replacement part isn't expensive iirc Link to post Share on other sites
niggelvr6 0 Posted June 16, 2008 Report Share Posted June 16, 2008 it is a main water pipe mine split and water rushed out not sure if it will cause pore running you can get the pipe from vw i belive it was about 50 quid just descrive it to them they will find it on the system Link to post Share on other sites
