petervr6 0 Posted February 24, 2007 Report Share Posted February 24, 2007 was just driving home stopped at the lights then pulled off a little hard then there was nothing just a grinding the car was in gear but would not move just makes a grinding sound any ideas i had a look at the shafts they seem to be intact. Link to post Share on other sites
Eat this 2 Posted February 25, 2007 Report Share Posted February 25, 2007 have you rtried diffrent gears is it just 1st gear? Link to post Share on other sites
rodney 17 Posted February 25, 2007 Report Share Posted February 25, 2007 Do you have full clutch pedal motion??Can you feel a bite point???Do any gears engage???Does the gear lever go into any of the gear positions (don't forget reverse)???Does it try and stay in gear if you get it in gear and is it difficult to pull out or try and jump out????Do you get any noises when in Neutral also place preasure on the lever to engage withoput dipping the cluch (don't actually engage the gear tho' and any of the gears)???This will help us establish if you have shreaded a gear, have drive/halfshaft issues, Thrust bearings etc etc.. Link to post Share on other sites
petervr6 0 Posted February 25, 2007 Author Report Share Posted February 25, 2007 silly me didnt look prop the dive shaft poped out the drivers side Link to post Share on other sites
petervr6 0 Posted February 25, 2007 Author Report Share Posted February 25, 2007 got some pics i will post up to show you. Link to post Share on other sites
petervr6 0 Posted February 25, 2007 Author Report Share Posted February 25, 2007 some pics first picture show what it should look like.[lightbox=../../e107_files/public/1172438434_2547_FT161168_24022007235.jpg][/lightbox][lightbox=../../e107_files/public/1172438434_2547_FT161168_25022007238.jpg][/lightbox] Link to post Share on other sites
craggsy 91 Posted February 25, 2007 Report Share Posted February 25, 2007 Hows it manage to "just pop out"? Link to post Share on other sites
petervr6 0 Posted February 26, 2007 Author Report Share Posted February 26, 2007 aint got a clue i pulled off quite hard then it just died with the horrible grinding noise. Link to post Share on other sites
craggsy 91 Posted February 26, 2007 Report Share Posted February 26, 2007 I thought the hub nut holds drive shaft in Link to post Share on other sites
lee060 3 Posted February 26, 2007 Report Share Posted February 26, 2007 engine mounts worn?? when accelerating hard lifting the engine thus causing the shaft to pop out?? the only possible explanation???Liam Link to post Share on other sites
petervr6 0 Posted February 26, 2007 Author Report Share Posted February 26, 2007 ye i think your right mate i was having a look today and i was pushing the engine back and forth with hand and there is a bit of movement in the mounts.im going to strip it down tomoz and have a better look im hoping its just poped out and not snapped but it looks like it has just poped out. Link to post Share on other sites
petervr6 0 Posted February 26, 2007 Author Report Share Posted February 26, 2007 I thought the hub nut holds drive shaft inthe hub nut holds the cv joint into the hub but the joint itself bangs onto the drive shaft. hope that make sense for ya mate. Link to post Share on other sites
craggsy 91 Posted February 26, 2007 Report Share Posted February 26, 2007 Ah all becomes clear now Link to post Share on other sites
petervr6 0 Posted February 27, 2007 Author Report Share Posted February 27, 2007 ok stripped it down and the c.v joint has broken its lost the ball bearings and some other little bits inside it. Link to post Share on other sites
petervr6 0 Posted February 27, 2007 Author Report Share Posted February 27, 2007 Hows it manage to "just pop out"?the end of the drive shaft has snapped off. Link to post Share on other sites
